My solution to Wheel Vintiques Series 62’s
So I recently purchased a set of Wheel Vintiques series 62’s from Summit for my 74. 15x6’s and 15x8’s, I’ve ran them before on my 67-72’s, so no big deal right? They show up, I paint them, get my tires mounted, go to put them on...the rears don’t fit. So naturally I come here and search and find out there’s fitment issues with the Squares with the bigger rear drums. Swapping to the smaller brakes wasn’t an option out of pride because my shoes and drums are brand new. So after some measuring and research, here's what I came up with.
I needed a 1/2” spacer to get the drums to clear the backside of the windows on the wheels. My lug studs were too short to work with a spacer so I would need to replace them. I couldn’t seem to find a longer stud with the same diameter knurl so I went hunting. I also didn’t want a stud so long I needed to pull the axles to install (just resealed the diff and put fresh fluid in). I came up with these lug studs, that I believe fit a Mercury Mountaineer. Dorman 610-514. Still 1/2-20 thread. Here it is next to the stocker.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 04-08-2022 at 09:34 PM. |
Re: My solution to Wheel Vintiques Series 62’s
It even has a “clipped” side to help it clear the bearing housing when you put it in.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Stock lug stud knurl diameter-
New stud diameter-
After using a 35/64” drill bit to open the axle flange stud holes, they go right in with the axles in place.
I bought a Bosch drill bit off Amazon for $13. Using my drill on low speed with plenty of cutting oil the bit held up like a champ and cut the last hole just as quick as the first.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 04-09-2022 at 03:42 PM. |
The right tool for the job always helps.
Here’s a mock-up showing the clearance I have now. That’s a feeler gauge, the only thing I could find that would sneak in there, with plenty of wiggle room, I was able to rock the feeler gauge side to side.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 04-09-2022 at 03:39 PM. |
All finished up, just hand tight, more threads are exposed after torquing.
All in I spent $160 between Summit and Amazon. That includes buying the drill bit and having to pay shipping from Summit since I was just under $100 on my order.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 04-08-2022 at 11:37 PM. |
One more.
Good tip!
![]() Join Date: May 2010
Cool Thanks for sharing!
It only has original paint once |
Great little write-up, Chris. Nice truck. It's amazing Wheel Vintiques didn't do their homework with these 62 series wheels, since the 5 on 5s would be made primarily for C10s
Thanks Tim, hoping I can offer a different alternative to a brake swap.
I agree with you, seems like they could have done a little more R&D on them.
#15 |
Old Heap Driver
The wheels look great, love steelies and dog dish caps.
Dorman is a great source for lots of items but especially wheel studs.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
#16 |
I have a set of these wheels on order with the rears being 15x10 w/5.0 BS. So, does that mean I can expect the same problem? I don't think spacers are going to be a viable option for 10" wide rims with 295 tires.
#17 | |||
I would agree there should be a disclaimer on the website but it's possible they're not aware of the issue since most C10's don't have the HD drums. The info should be shared w/them that they don't fit over the HD drum set-ups beyond a certain back-space dimension. They fit the standard brake packages fine which is what the majority of C10's have. For use on HD drum packages, the wheels beyond 3.5" of BS are not a direct fit. I can't see any company re-inventing the hub/center of a wheel to accommodate a select few possible purchases. Order the BS @ 3.5" ($25 fee) & there shouldn't be an issue. Quote:
Set-up looks good Chris!
#18 |
I just got the truck a couple weeks ago. So, I'll have to check which drums are on there. And the wheels are on order. Not sure when those will show up. The 5" BS on the 15x10s is a custom order (4.5" BS is standard). So, I'm probably stuck with them either way. Sure hope they fit.
#19 | |
Also.... Those 295's are fairly short for the rear of a truck @ <27 (26.6"). What's the plan for the fronts?
#20 | |
#21 | |
They are 4 1/4” BS. I think that’s the standard on them. All the 62’s I’ve ran have been 4 1/4” BS on 15x6, 15x7, and 15x8’s. The method I used here would only work for widths up to 8” I would assume without a custom backspace. The issue with these wheels and the HD drums is the outside mounting surface of the drum is recessed in about a 1/4” deeper than the lip on the outside of the drum, so the lip on the outside edge of the drum hits the backside of the four window openings on the perimeter of the wheels before the inner wheel mounting face touches the drums outer mounting surface. It’s been so long since I’ve seen the back of a GM steel wheel I’d love to see a pic to compare how GM’s windows in the wheels are rolled in compared to Wheel Vintiques.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 04-12-2022 at 04:21 AM. |
#22 |
HD drum-
#23 |
11x2” standard drum. Without the recessed mounting face.
#24 | |
I tried the HD set-up w/8" wheels when I was looking for budget friendly wheels for my '64 years ago. I don't recall the exact specs but pretty sure they were 4"BS. It's been >12yrs though so.... I knew I was going wider than 8" so I stepped up to 16" (16x10's) & was able to mount them on the standard or HD set-up. I'm guessing Wheel Vintiques has different 'standard back-spacing' depending on series/bolt-pattern/size. I got 15x8" 62 Series for my Malibu & they were 4.25"BS standard. The similar '82 Series' for my 3/4 ton OBS came w/4"BS standard (16x8" 8-lugs). I wound up ordering a 2nd set of those w/custom back-spacing @ 5" & selling the 1st pair of 8's.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-12-2022 at 09:05 AM. |
#25 | ||
But to your point, I’ve ran these wheels in 8” on my 67-72’s (67-70’s I’ve had 71/72 rears in) with no issues before. Quote:
So many different variables in this hobby of ours, remember how much more difficult and time consuming this was before the internet?
