Old 05-09-2022, 11:58 AM   #1
SchmidtM
67 PICKUP floor pan help
I ordered left and right floor panels. First from LMC the AMD. Both of the are the same mold and appear to be wrong. On my original floor the seam is straight across the new one is bowed
So what am I missing guys?
SchmidtM is offline   Reply With Quote
Old 05-09-2022, 01:13 PM   #2
Jason Banks
Jason Banks's Avatar
Re: 67 PICKUP floor pan help
On that patch panel, as well as most others, you are only supposed to use part of it. You need to cut it up into patch panels for the areas you need. It is not perfect, but it is close enough to be trimmed and hammered into submission.
If your whole floor is bad, you are probably best off buying a whole replacement floor. They seem to bee good parts.
Jason Banks is offline   Reply With Quote
Old 05-09-2022, 04:03 PM   #3
cj847
cj847's Avatar
If it is like mine, the panel covers that seam completely (and a couple of inches of the firewall). It doesn't have a 90 degree bend down to match to the firewall.
On the driver's side pictured it does appear that the corner is bent where the dimmer switch goes.
Also note: on the projects tab Kyle Seal (My 67 build finally) post 37 shows a true drivers floor pan; what you have is referred to as a drop in floor pan.
cj847 is offline   Reply With Quote
Old 05-09-2022, 04:57 PM   #4
Caddylackn
Caddylackn's Avatar
There are two different type of panels. There are replacement panels. They require full or partial removal of the old panel, cutting the replacement to the exact opening size, and full perimeter butt welding to the old metal. The replacement panel may or may not be an exact duplicate in the center of the panel but should match up around the edges. The exact replica OEM replacement panels should be an exact replica, and thus they are the most expensive.
Then there are repair panels, which are designed to go over the top of the old panel with a 1" or 2" overlap and the center of the old panel removed. These can be lap welded or spot welded in place, then seam sealed around the edges.
The repair panel does not fit like a replacement panel, since it has to fit on top of the other panel, the radii of the curved areas are larger. They don't line up well if you try to butt weld them in like a replacement panel.
It looks like you have a repair panel. You should be able to make that one work, I would trim it to fit over the top of the old panel, then decide where to trim the replacement panel so you know where to cut out the original panel so you have enough over lap. Then trim it to final size, then fit it and trace around it to transcribe to the old floor. Then cut your old floor out, leaving 1" -2" inside the line for lap. Then I would drill 3/16" holes in the replacement panel about 3/4" from the edge every two to three inches around the perimeter. Then you can throw a few self tapping screws around it to hold it in place for welding and keep the panels tight together. Then tack weld it to the old floor through the 3/16" holes, then remove the screws and fill those holes, then seam seal the perimeter, then paint, your done. You can get a decent fit/finish with a replacement panel, but it won't look factree when viewed under the car.
The beauty of a replacement panel that is overlapped is that you can get one of these in and welded from start to finish in a few hours, compared to many hours for a replacement panel with a full perimeter butt weld and ground down and finished. If the truck has carpet, you will never know which one you used. You should seam seal the bottom if you can or use a heavy undercoating on the lap weld on the underside so water doesn't get in between the panels.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
