Old 05-26-2022, 03:34 PM   #1
Nima
Blue 67
Upper Radiator support bracket
Hi:
I am replacing my radiator as part of my LS swap project. My stock GMC radiator has side mount fill versus this new one (I assume is for Chevy) is top mount fill. So, Not only I have bring the radiator down for upper bracket to clear the radiator cap, but it seems I have to cut the bracket to be able to open and remove the radiator cap in the future. I was wondering if the Chevys' upper radiator bracket is different, since to my understanding is that GMC radiators are the only ones with side fill. Pictures would be great.
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 05-26-2022, 07:47 PM   #2
mr48chev
mr48chev's Avatar
Re: Upper Radiator support bracket
We have to see good photos of this and Brand and part number of the radiator won't hurt as it will help one of us figure it out.
My ongoing truck projects:
Old 05-26-2022, 09:05 PM   #3
Nima
Blue 67
Okay, this may make it a little complicated!
I am moving the radiator outside (toward the front) of the rad support to have more clearance for Ford Taurus fan and other accessories. That is what you see in the picture but regardless, the upper support would hit the top fill cap. I just want to know if there is an easy way of just buying a chevy upper support or if I should just go and make my own. I know that I have to trim the corners as well.
The radiator brand is Mishimoto and this is the link:
https://www.mishimoto.com/chevrolet-...ml#prettyPhoto
Old 05-27-2022, 12:42 AM   #4
mr48chev
mr48chev's Avatar
The Chevy radiator (it appears to be rather than having a GMC filler neck on it) was never going to work right on the GMC anyhow.
The cure is to leave that cap on or a low profile cap and run an inline filler neck in the upper hose. https://www.ebay.com/itm/131638888119
The correct GMC radiator sets further forward with it's mounting brackets Than a Chevy radiator does. Similar to this one https://www.ebay.com/itm/33437238711...gAAOSwRO1iIB0O
You can see how the Champion made for a GMC moves the core forward over 1/2 inch. https://www.ebay.com/itm/29429804268...cAAOSwX7FicQ2S
Old 05-27-2022, 09:50 AM   #5
Nima
Blue 67
Thank you for all the information. Very helpful.
