01-01-2004, 04:43 PM | #1 |
wont start
after breaking in the cam on my 86 305, i changed the oil, and checked everything else out. i checked the timing, and it seemed to be at an acceptable point. the truck was running ok at that point. i then took it down to the gas station to put some gas in it, on the way down there if i would let off the gas it would die. when i first brought it back from the gas station, if you cracked the throttle open a bit it would run, but as soon as you let off, it would die. i went out to start it and move it the other day, and it wont even start. anybody got any ideas?
01-01-2004, 06:33 PM | #2 |
check for vacuum leaks and disconnected hoses. That's the first thing I would do
01-01-2004, 07:14 PM | #3 |
i see no disconnected hoses, and how does one check for vac leaks if it wont start?
01-01-2004, 09:26 PM | #4 |
Available for Adoption
Is it getting fire? if so, do the plugs look fuel fouled?? If not, try a little starting fluid. Sounds like a fuel problem, but I may be wrong. Hard to tell from here..
1983 C10 SWB 2001 Silverado SWB 1995 Corvette |
01-01-2004, 09:49 PM | #5 |
Professional Grade
might be a bad gasket somewhere...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
01-01-2004, 10:12 PM | #6 |
pull a plug and check for spark. then pump throttle and check for gas
80 Chevy K10 350/350turbo 86 Chevy 1/2 ton shorty project truck 79 Chevy 1/2ton 350/350turbo not much to look at... ***Retired*** 97 Chevy C1500 4.3/5 speed.....daily driver |
01-01-2004, 10:16 PM | #7 |
Project92 SWB stepside
Also check your linkage hook up. If it is way out it may not be holding it open far enough to start.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
01-02-2004, 03:06 AM | #8 | |
01-02-2004, 03:08 AM | #9 | |
01-02-2004, 06:06 AM | #10 |
do you have any spark???
01-02-2004, 01:50 PM | #11 |
driving is in my blood
Fuel pump go down the hole......
Check for fuel first, then spark.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-02-2004, 07:01 PM | #12 |
Slots go on anything!
it sounds to me like the distributor moved. I would recheck that first.
1974 Jimmy- 5.3/4L80e/NP241 |
01-03-2004, 05:47 AM | #13 | |
I had a similar problem after break-in also, but after 20 minutes of scratching heads, I looked over and noticed the see thru fuel filter was only 1/4 full, not feeding enough gas to the bowls. fixed the kink and ran like a champ, till my distributer losened up and as from above you know the rest ..... |
01-03-2004, 05:35 PM | #14 |
well, its gettin fuel, and fire. just for kicks and giggles, i poured a bit of gas down the carb (didnt have any starting fluid) and it made no difference. once in a while it acts like it wants to fire, but then nothing.
01-03-2004, 07:10 PM | #15 |
Sounds like a possible timing issue....Assuming it's getting a good blue spark......
