Old 06-12-2022, 12:46 PM   #1
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Truck/Blazer Console questions on Repair and Repops
I have searched the forums and google and really havent found the answers I have been looking for.
I am in the process of putting together the 69-72 style buckets for my 68 C10. I picked up a console that is in pretty good shape minus a huge hole in the side near the rear on the upper piece where it meets the lower. I have seen repair threads and videos for smaller holes and cracks but nothing for a large chunk missing. Has anyone made a patch to fix a missing chunk? I know I am gonna have the texture issues, but this is really the only thing really wrong with it and it should be saveable, jut at a loss on how best to repair it.
With that chunk having me buffalo'd, while searching I looked at the seatbelt buckle style reproduction consoles and pondered those with how crazy expensive originals are going for now. Pic is of what online ads show. I cant seem to find a picture of this style in actual use. The main concern I have is if the top area is the same size so you could add all the trim to make it look more presentable than a block of plastic.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 06-12-2022, 01:41 PM   #2
HO455
HO455's Avatar
Re: Truck/Blazer Console questions on Repair and Repops
Could you post a photo of the damaged console? It may help us visualize what you're up against. Who knows maybe someone's got the piece you need just taking up space in their garage.
You also might watch some plastic welding and dash repair videos. You might gain some insight as to how to move forward.
Good luck and let us know how repair goes.
RIP Bob Parks.
Old 06-12-2022, 02:06 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
The originals are a sort of fiberglass. You should be able to get some resin and some cloth to repair and skim with Bondo to try your luck with texturing.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 06-12-2022, 08:10 PM   #4
CAMAROBOY68SS
This is the hole I am dealing with. I figured I was gonna have to cut to a clean area to the patch once I strip off the bucket of paint someone sprayed on this. I mainly picked it up as the lid is in super shape as well as the trim ring.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 06-12-2022, 08:23 PM   #5
Grumpy old man
Grumpy old man's Avatar
This should work . That corner always gets broken / cracked when 2 people try to sit in the passengers seat .
https://www.youtube.com/watch?v=lnTTcZv4B54
Old 06-12-2022, 10:30 PM   #6
dagnabbitt
dagnabbitt's Avatar
it depends upon your goals for the truck and what you use your console for. If the truck is a daily driver that you don't plan to restore, and the console is just a place to keep your stuff then a repop is fine.
But if you have any plans whatsoever for your truck and you like originality, trust me, you will be immensely disappointed by the repops. Ask me how I know. I have a couple and I do plan to add some bling to them to make them a little nicer but I'd rather have an original with a chunk missing, frankly.
Since these are not made of plastic, acetone is your best option, it will melt that paint off and leave the console intact, then you will know what you are dealing with. I am fixing a couple up right now with fibreglass that I usually use on boats. The chunk you have missing will not be that visible when installed, so give it a try.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-13-2022, 04:04 PM   #7
70STOVEBOLT
70STOVEBOLT's Avatar
X2 on using acetone for paint removal, it will strip it to the bare fiberglass.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
