![]() Join Date: Jan 2012
Heat Stove Screw Size
Anyone know the correct size of the heat stove screws? I'm missing the two that hold connect the stove pipe to the heat stove, also missing one of the top heat stove screws. Are the ones that connect the pipe to the stove the same size as the others along the top of the stove?
Also, do they reproduce the two heat stove pieces or will I need to restore my originals? I know the pipe should be black but what finish would the stove have had? I assume most finishes will burn off due to the proximity to the exhaust manifold. Pics of what I'm talking about. |
Re: Heat Stove Screw Size
Found a thread that answers my "original finish" question https://www.67-72chevytrucks.com/vbo...d.php?t=670464. Still not sure about the screw sizes.
![]() Join Date: Sep 2011
#10 sheetmetal screw with 5/16 hex
1967 C10 SWB Owner - Rustbelt Restorations |
Hex head? My originals that are left are pan head Phillips.
I have the original set up on my 71 C20. The screws are sheet metal with hex heads.
71 C-20 07 Magnum RT AWD |
Interesting, wonder if they made a change from 70 to 71. I feel like the "patina" looks pretty uniform from screw head to stove metal to lower nut & bolt. I guess I really just need to figure out if all the holes are the same size. Also, I can't find a repop of the heat stove so I guess it's not reproduced.
I am referring to the two used to secure the pipe up to air cleaner.
While doing some more searching through the forum I ran across a thread by IronCanine on the subject of heat stoves. davischevy posted a couple pics of his 56,000 mi C10 and it appears that all screws across the top are indeed hex head. It appears however that the two for the pipe have larger heads than the others. Looks like my two Phillips screws are OLD replacements.
Here are davischevy's pics. |
I'm trying....
![]() Join Date: Oct 2013
I believe the hex head sheet metal screws are correct for both the tin to tin connection and the tube to tin connection. I don't think there is a specific call out in the assembly manual, but I'll check tonight as well as post some pics of originals I have at home.
Most of the time those tins came off and never went back on...but if they did, it wouldn't surprise me if a lost screw got replaced or if a hole was wallowed out and a larger screw stepped in. Also, hardware could be variable amongst plants or time periods...so it is conceivable that other hardware may be seen. Every one of these that felt honest and original to me had hexes.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#10 | |
![]() Join Date: May 2001
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
#11 | |
![]() ![]() Join Date: Sep 2008
I'm trying....
Parts manual calls for #8-18. All the ones I have are just that. Some have an M makers mark. 1/4" socket fits em all. I don't doubt that the tube screws could have been #10s from the factory. It makes sense, those are the screws really under a load. Also, the ones most likely to get wallowed out and get upsized IMO.
Also, Larry has previously made a point about what he has seen finish-wise on low mileage examples he's owned...and I've recently seen it myself. It appears the outer half of the heat stove tins was painted black and the inner half was unpainted. You can see it in the pic Chris posted of Larry's truck and in the rough original example shown below.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 06-20-2022 at 11:09 PM. |
I'm trying....
Thanks for all the great info and pics guys. What would you think the original finish on the fasteners would've been, black oxide? Any recommendation on a source for some new replacements? M maker's mark not necessary.
