Old 06-27-2022, 10:29 AM   #1
DLH
Driveshaft phasing
When I bought my truck, it didn’t have a driveshaft. I found one local to me that was free. I am taking it apart to cleanup and rebuild. I noticed that the front yoke (ujoint) is not in line with the rest of the u joints. Looking at the pic its sitting about 11 o’clock. That’s not right, is it?
David
DLH is offline   Reply With Quote
Old 06-27-2022, 10:44 AM   #2
kwmech
Re: Driveshaft phasing
No it's not, and it's actually sitting at 2 o'clock or 8 o'clock if it's 180 out
Old 06-27-2022, 10:53 AM   #3
72SB
FWIW GM did that on cars, Camaro back in the 1st gen years in an effort to eliminate driveshaft vibrations. On paper the "theory" looked good but in practice it did not. My 67 Camaro had it. The idea that under load the out of phase U joint would eliminate driveshaft vibes, especially on vehicles with low rear end gear ratios.
You can have the yoke end removed and positioned in line with rear at a good driveline shop and have the shaft re-balanced
If getting a new DS..and your wallet is thick enough. Get a Dennys DS, especially if running 3:73, or lower, gears
72SB is offline   Reply With Quote
Old 06-27-2022, 01:28 PM   #4
DLH
I removed the yoke and tried to reclock it, but it is a half spline off from lining up if you know what I mean. I'll get it cleaned up and take it to the shop and let them cut the end off and fix it. At least the driveshaft was free.
David
Old 06-27-2022, 02:32 PM   #5
Keith Seymore
Keith Seymore's Avatar
"Phasing" was one of those design theories that came and went, depending on what was en vogue at the time.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-27-2022, 04:55 PM   #6
tdangle
tdangle's Avatar
Interesting note: I have a 2 piece drive shaft that was rebuilt and balanced by a driveline shop. In trying to track down a vibration I have at speed I unphased my driveshaft a couple of different ways with absolutely no change in the vibration. In theory it makes sense, in practice not that I could prove.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-27-2022, 05:22 PM   #7
Bigdav160
Bigdav160's Avatar
That thing has to shake like crazy
edit: maybe not if the working angle on the front joint is 0
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-27-2022, 05:36 PM   #8
67C10Step
67C10Step's Avatar
Hmmmm, I need to crawl under my 67 and take a look. I am almost certain that is exactly how mine was when I pulled it out for rebuild and how I put it back together. I've not had mine much above 55mph in the few miles I've driven it but I've not noticed anything overly bad on the vibration front.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
