Old 01-02-2004, 06:09 PM   #1
Daves72'GMC
Question hei?
I have the origional 402 BB in my truck and want to upgrade my origional distributor to a GM HEI unit . What year distributor do I look for in an Hei unit? Thank you
Daves72'GMC is offline   Reply With Quote
Old 01-02-2004, 06:43 PM   #2
rage'nrat638
rage'nrat638's Avatar
74 and up
rage'nrat638 is offline   Reply With Quote
Old 01-02-2004, 07:19 PM   #3
mooneyes
mooneyes's Avatar
74-till they went computer controlled..which most had no vacuum advance and an extra plug and wires..at least thats the way it is with small blocks...correct me if i'm wrong guys....
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 01-02-2004, 07:28 PM   #4
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
You can use the computer controlled distributors as well. Here's the trick: on the 4 wire lead that comes out of the distributor to the computer controller, connect the "A" and "C" wires together with a spilce (sorry, forgot the colors). Works every time.
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 01-02-2004, 08:08 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Dave, keep in mind, a small block and a big block use the same distributor. Never tell the guy at the junkyard you want anything "Big Block" unless you bring your Vaseline. Tell him you want a distributor out of "that old car over there with a small block in it"......Much cheaper that way.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-02-2004, 10:42 PM   #6
ckenwright
ckenwright's Avatar
Perchjerker, what do you do with the other two wires?
ckenwright is offline   Reply With Quote
Old 01-02-2004, 10:54 PM   #7
Tx Firefighter
You just leave them disconnected.
A to C will make it run.
Old 01-02-2004, 11:09 PM   #8
ckenwright
ckenwright's Avatar
I recently passed up an HEI because of the computer control. Maybe I will try it now. Thanks
Old 01-02-2004, 11:16 PM   #9
Tx Firefighter
There are different types of computer control distributors. The type Perchjerker is talking about is the ESC one, or Electronic Spark COntrol, commonly used in early to mid 80s trucks. It looks just like a normal HEI, but it has an extra black 4 wire plug coming out of it. If you lift the cap off, you will see that the module has lots more pins on it.
Old 01-02-2004, 11:22 PM   #10
HEAVY CHEVY
BOWTIE FOREVER
HEAVY CHEVY's Avatar
So let me ask this question about hei,whats the difference in the setting for hei and points? They say number 1 on the points distributor needs to point at the 7o'clock and the hei number 1 points at the 5o'clock,So whats the difference?
69 C-10 SHORT FLEET BED
350 4-BOLT/400 turbo
upper & lower molding
65 IMPALA 2-DR
283/POWERGLIDE
66 IMPALA 2-DR
hopefully 283/350
~ CAMELTOE ROCKS ~
HEAVY CHEVY is offline   Reply With Quote
Old 01-03-2004, 01:34 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
#1 is where ever you put it.
Don't overlook vans for HEI donors. They ran non computer ones longer than cars, and you can pull them out from the drivers seat. (also a good place to find inline 6 engines with HEI)
