![]() Join Date: Jul 2015
Battery on/off switch location
Where do you guys locate your battery switch? I'm not sure if I want it in the cab or under the hood. Not really placing it there as a theft deterrent, just having a handy place to be able to disconnect the battery, especially if I need to do it in a hurry.
Here the one I purchased, not sure if there are better ones?
1963 C20, small window, long bed 292, 4-speed |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Battery on/off switch location
These will do that. https://www.amazon.com/Battery-Termi...32611961&psc=1
![]() Join Date: Feb 2010
It's Better With Nitro
I used a push/pull Flaming River master disconnect switch that was a back up for my old drag car similar in type to the one in the OP's post (bus bar switch). It's mainly a theft deterrent for my C10, but also meets tech in case I run my truck down the drag strip since the battery is mounted on the frame in the rear. The cutoff switch is mounted on a bracket on the driver side rear of the frame and the rod is easily removable. The hole in the bumper was from the truck's previous owner, so I kept it for the push/pull rod.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
