07-27-2022, 11:36 AM | #1 |
1968 GMC 250 Inline 6 4.1L Chugging
I've reached the end of my patience... . My 250 inline 6 starts and idles fine. It will run down the road like a champ for a mile or two then start chugging and backfiring real bad. When I let off the gas it idles fine then it starts chugging and backfiring again a little ways down the road. Here is everything that has been done...
New gas tank and sending unit 3 years ago Carburetor professionally rebuilt fall of 2020 Distributor professionally rebuilt fall of 2020 New cap, rotor and points New AC Delco plugs and wires last summer New coil this spring New fuel pump (last summer and again yesterday) New fuel lines New carburetor fuel filter (last summer and yesterday). Old ones looked good. New vacuum advance line for distributor to carb I'm going to pull the sending unit out of the gas tank. It's been suggested that maybe the sock filter has collapsed (?). Any other suggestions or possible issues are greatly appreciated! Thank you! |
07-27-2022, 11:45 AM | #2 |
Re: 1968 GMC 250 Inline 6 4.1L Chugging
How often is it run? The 1 bbl on my original 70 would gum up when it set a lot. I would pull off the top, run some carb cleaner thru it and it would run fine until it set again. You may have a sticky power valve or jets from the gas. Only other thing I can think to check is the actual vacuum advance unit to see if it is sticking or not moving.
07-27-2022, 11:48 AM | #3 | |
07-27-2022, 12:27 PM | #4 | |
My 68 327 did this when going up hills and at near WOT . Turned out the rubber line going from the pump to the frame hard line was collapsing
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
07-27-2022, 01:39 PM | #5 | |
07-27-2022, 01:24 PM | #6 |
OP
You sure your choke is fully opening once engine warms up?? |
07-27-2022, 01:41 PM | #7 |
07-27-2022, 02:20 PM | #8 |
well manual choke should be open fully when pushed back in....so check choke linkage to confirm it does in fact open it fully. You don't need to drive it to do this
fuel pressure may be getting compromised. Maybe a kink in line somewhere?? an inline FP gauge comes in handy |
07-27-2022, 05:27 PM | #9 |
When a condenser goes bad in the distributor it will act like a fuel problem.
The quality of them is not that great any more. It's cheap and easy to replace. I'd give it a try. Good Luck |
07-27-2022, 05:29 PM | #10 |
IMHO, dich points all together and put in a Pertronix kit regarding stock dizzy.
with that said IDK if OP's issue is ignition related |
07-27-2022, 06:23 PM | #11 |
Never a good idea to introduce a new variable when trying to troubleshoot a problem.
A year ago you had questions about doing a tune up. You were advised to find a Dwell Meter rather than rely on setting the gap manually. A year later the points are possibly corroded, pitted and in need of cleaning and readjusted. File with small metal file. After point adjustment, check and reset timing. Spray carb cleaner around intake manifold while running and check for vacuum leak.
'67 GMC 2500, 292, 4spd, AC |
07-27-2022, 09:01 PM | #12 |
Choke is working properly
07-27-2022, 09:26 PM | #13 | |
07-27-2022, 10:23 PM | #14 |
One thing I should mention... The truck came from California and it still has the original Air Injection Reactor (A.I.R.) smog pump. Thought I would mention this in case it could be part of my issue.
I know there will be responses that tell me to remove it but I would like to keep things as close to factory as possible. |
07-27-2022, 10:53 PM | #15 |
Who Changed This?
The A.I.R. system is not the cause of your problem. Anyone removing the system did it because they either didn't understand the function or didn't like the buzzing the pump made. Or maybe some other reason that I don't know about. But it won't cause your problem.
07-27-2022, 11:48 PM | #16 | |
08-12-2022, 05:57 PM | #17 |
A gap setting is more of a starting point. Back in the day I use to wrench fullt ime and what I did was set peoples points with a match book cover to get it running. Faster to grab than a filler gauge and then find the one you need. Then hook up a dwell meter and dial them in better. The dwell setting is a more accurate setting. I even kept a match book in my glove box incase the points slipped on the car I drove. lol I dont think you will have crap clogging the sock in your tank as you said you have a new tank fuel lines and pump. If you do change gas stations. Another thing kind of related to crappy gas is water in the tank. The place you get gas from may have a lot of water in thier tanks or if you got gas while the fuel truck is filling the stations tanks. And in that case you can have crap in the new tank and water. If you dont find an issue have someone crank it over while you hold the fuel line hose in a jar. Get a good sample then let it sit. The sample that is. After a good while look at the fuel in the jar. If theres water in it you will see it on the bottom of the jar. Water is heavier than gas so it will settle to the bottom.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
08-15-2022, 10:14 PM | #18 |
Well... The truck is now running like a champ. I changed the points, condensor and coil (again). Checked dwell and timing. Looks like it was ignition related after all.
I'd like to thank everyone for their help! I hope to be able all of you some day. Thank you! |
08-16-2022, 09:25 AM | #19 |
Nice! Glad to hear you got it going good. Now you can enjoy it.
07-27-2022, 10:08 PM | #20 |
I've held off commenting, but my 1968 with 250 has basically the same problem.
I've always thought it was a fuel problem. I have HEI and have rebuilt carb a couple times. Truck also has a new fuel sending unit/pickup and the tank doesn't look like it has trash in it. I loved hearing 72c20customcamper say that it was a fuel line collapsing because the symptoms he was describing is just like mine, slight incline, near WOT trying to go 69-70mph on the highway with 4:10 rear gears. It starts bucking and you have to let off the gas and slow down for it to get better. Doesn't always happen, you can run for miles at about 70 then it just chokes. Interested to hear what you find out. I'm thinking I'll inspect the rubber lines, but I know I've replaced those in the past. Might try something stiffer, like some PTFE lined AN line. I've been neck deep in my other truck and kind of neglecting the other one... |
07-28-2022, 09:05 AM | #21 | |
07-28-2022, 09:19 AM | #22 |
To me sounds like something awry in the ignition system. Like a few others have said check your points gap, initial/total timing, confirm your vacuum advance is working properly. Also run your multimeter on the negative side on coil, throttle it up and check if your condenser going bad.
07-30-2022, 07:51 PM | #23 |
>>but what does setting the points with a dwell meter vs manually have to do with them becoming corroded and pitted?<<
I didn't say it did. New point contacts are smooth and shinny. After a few miles they take on a course appearance caused by about 300volts arcing across them when the points open. If you don't understand where the 300 volts comes from, you need to read up on the Kettering Induction Ignition System. In the first image, the enlarged points show a course, gravelly surface. They show a .016" gauge giving a .021" actual gap. Filing with a small metal file will help provide better results and in the end a more reliable dwell. But, they still won't last as long as new before they need attention. The real problem with using a feeler gauge is that it requires a delicate touch. The point arm spring is relatively soft and the feeler gauge is a metal pry bar. If you don't take the feeler gauge out of the pack, the gauge pack acts like a pry bar handle, giving even worse results. If you ask 10 guys to set the gap on your dist and check with a dwell meter, you'll probably find 3 guys that set the gap correctly. The second image shows misaligned contact points that will go out of adjustment very rapidly. Many guys don't bother to check and the Chinese made points are worse than ever. A couple guys mentioned the condenser. The easiest way to check to see if the condenser should be replaced is to look at the used points. The condenser should be 0.18 - 0.22 micro farads. In the first image you see metal transferred from one contact point to the other. The job of the condenser is to suck up that 300 volts. If the condenser capacity is too large or too small, metal will be transferred from one point contact to the other.
08-02-2022, 08:12 PM | #24 |
RICHARDJ
Thank you for the information and the pictures. I checked the points tonight. They still look like brand new and the alignment looks good. I hooked up a dwell meter. Should be between 31-34. It registered at 31. |
08-02-2022, 09:11 PM | #25 |
UPDATE..
I have done the following: Replaced the fuel pump Replaced the sock filter on the fuel sending unit Replaced the fuel filter in the carb Blew out fuel line from sending unit to fuel pump Blew out fuel line from fuel pump to carb Replaced rubber fuel line from sending unit steel line to fuel pump Replaced vacuum line from distributor to carb Replaced vacuum line from smog pump to carb Confirmed vacuum advance canister is good Confirmed vacuum advance arm is working Checked vacuum at carb Confirmed manual choke works properly Confirmed points/dwell set properly Confirmed timing Confirmed RPMs New exhaust (it was needed) Going to have the carb checked again (was rebuilt last year). I don't know where to go from here... Last edited by 68gmcdude; 08-02-2022 at 10:19 PM. |
Tags |
1968, 250, backfire, chugging, gmc |
