Old 01-03-2004, 01:26 AM   #1
GMC70c20
tips and trick of the 383
I would have put this one on the engine and drivetrain board but it dosent work. what is any tricks or tips you 383 guys have picked up or heared of about building a 383.
GMC70c20 is offline   Reply With Quote
Old 01-03-2004, 01:31 AM   #2
rage'nrat638
rage'nrat638's Avatar
well the cheap way is to use a 400 crank....
the high dollar way is but a 383 stroker crank...
eather way you need stroker rods...
the block will need clearenced
rage'nrat638 is offline   Reply With Quote
Old 01-03-2004, 01:49 AM   #3
djracer
djracer's Avatar
the block has to be clearanced but you don't have to have a different rod! I'd reccomend buying an eagle kit it comes with a balanced rotating assembly!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-03-2004, 02:44 AM   #4
68c10owner
68c10owner's Avatar
i would`nt use the 400 crank. you can get a crank from scat that cost a little more/less than a cut down 400 and it`s stronger. they are available in nodular iron or cast steel. they are around $300 depending on where you shop. you have to cut the main journals down on the 400 to fit the 350 mains and it can weakin the crank. as far as the rods go, if you use 400 rods you don`t have to modify them. if you use 350 rods, you`ll have to grind the rod bolt and this is good for around .550 lift. my buddy had a 383 with 350 rods and he was running a crower solid cam with .550 lift. you`ll have to notch the block at the pan rails for crank clearance. these are very popular motors and any machine shop can do the work for you.
Anthony
68c10owner is offline   Reply With Quote
Old 01-03-2004, 04:03 AM   #5
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
or you could buy mine and save a ton of cash...
http://67-72chevytrucks.com/vboard/s...threadid=80269
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 01-03-2004, 04:19 PM   #6
GMC70c20
thats one hell of a motor but I didnt want to break $2000 on the motor. Have you had it dynoed if so how much hp/torque did it make?
this ones for the first reasponse where can I get one of those kits?
Old 01-03-2004, 04:41 PM   #7
bigjimzlll
bigjimzlll's Avatar
you can buy a 383 crank for under 200 bucks on ebay..you will need stroker pistons...and a 400 flex plate and balancer..it will need to be balanced also...the cost of everything(cheap) is around 650 with machine work...thats for a bargain basement engine...step up to decent rods and forged psitons and a good crank..its well over 1500.00....will there be a big difference in performance?..not for your average combo...but if you plan on running it hard..it will stay together much longer
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-03-2004, 04:55 PM   #8
GMC70c20
I wont drive it everday, probably 4 or 5 times a mounth and not in the winter. I wont drive it hard everware, I will put the hammer down every once in a while but not all the time.
Old 01-03-2004, 05:03 PM   #9
bigjimzlll
bigjimzlll's Avatar
one more thing..if you are using stock 5.7 rods..have the machine shop clearance the rod bolt on each rod prior to balancing..also buy the pistons ..rings..wrist pins..harmonic damper..flex plate prior to having the machine work done
Anderson,CA
Old 01-04-2004, 12:18 AM   #10
GMC70c20
When you said $650 for machine work what were all the procuder's you were talking about.
Old 01-04-2004, 01:05 AM   #11
bigjimzlll
bigjimzlll's Avatar
thats including parts I was including bore/hone 125.00.. balance 125.00.. tank/cam bearings and freeze plugs55.00..pistons 100.00..crank 150.00..flex plate 50.00..balancer 50.00
Anderson,CA
Old 01-04-2004, 05:09 PM   #12
GMC70c20
I prob wouldnt get these items balacned because I am only going to wind it up to 5000 rpm at the most, and not that often: pistons 100.00..crank and rods.
Old 01-04-2004, 05:29 PM   #13
68c10owner
68c10owner's Avatar
if your not going to balance it, don`t build a stroker, even if your only going to go to 5000rpm. it`s cheap insurance to balance it and it isn`t that much more than a internally balanced motor. i know alot of people you ran 350`s that were not balanced and they ran fine but when you get into the heavy crank of the strokers(unless you get a lighter aftermarket one) swinging up tp 5k, you run a risk of knocking out bearings. my buddy had a 388 that wasn`t balanced and it never ran right, always giving him trouble. he finally sold it and bought as 350. these motors can be built on a budget but when you start skimpin` too much, your just throwing money away. shop around on the net or in the magazines to see who has the best deal. alot of places sell balanced rotating assemblys and the balance and flexplate,flywheel can be found pretty cheap.
Anthony
Old 01-05-2004, 03:04 PM   #14
grnddwn
belly dragger
grnddwn's Avatar
Has anyone tried to order parts from these guys they carry 383 kits
www.enginekits.com
grnddwn is offline   Reply With Quote
Old 01-05-2004, 05:20 PM   #15
'70_402
'70_402's Avatar
Hey man if you want a bad-ass motor that will produce some horsepower check out www.strokermotor.com they have all the stroker motors and stroker kits too!! that's where i got one of my motors!!
'70_402 is offline   Reply With Quote
Old 01-05-2004, 08:56 PM   #16
oldsub86
I recall an article in a magazine that related to the 383 stroker. I believe they used Summit parts and the amazing thing was the fuel mileage they managed to get. If I can find the magazine, I will provide some additional details. If I recall they had it in a Chevy 4x4 and were testing with and without a trailer. The figures were impressive. I thought seriously about doing it to my old Suburban as the mileage wasn't so hot. Motor was OK though so I never got it done before I swapped it for my 4Runner.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
