08-14-2022, 02:40 PM | #1 |
3 wire 10si alternator conversion
hello everyone,im upgrading from the external regulated alternator, to a 10si internal regulated 63 amp alternator. I have done a search on the forum, and see that the conversion is pretty easy and strait forward to do. my original wiring harness is from a 69 c10, and is in excellent condition, never been cut or altered, except for the fusible link at the battery, which I will be replacing with a new one.The only add on to the truck is a HEI distributor in place of the stock points distributor, and I am going to eliminate the stock resistor wire, and run a new wire for that. with that being the only modification to the system, has anyone ever had a problem using the original 12 gauge wiring and charge circuit. I had thought about upgrading the charge circuit to 10 gauge, but hate to cut into a perfect original harness, if not needed. I already have the plug and play conversion adaptor kit for the harness connections at the regulator and alternator. thanks!
:chevy |
08-14-2022, 09:50 PM | #2 |
Re: 3 wire 10si alternator conversion
I did the 3 wire conversion on a 71 GMC I have. I used the plug in harness adapter from American Autowire. No cutting or splicing and the original charging wire has been more than sufficient.
08-15-2022, 08:18 AM | #3 |
No need to cut and replace the factory charging wire . I added a 125 Amp alternator to my chevelle I just added another wire and zip tied it to the harness. So now I have 2 wires running from the alt to the battery . Never had a problem
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
