09-04-2022, 11:54 PM | #1 |
Is this a non E-Brake caliper?
These are on my truck, supposedly from CPP. I just finished plumbing the brakes and instructions I've found online say that I must adjust the parking brake before moving on. However it appears these rear calipers have no parking brake. Is that right? Am I ok to move ahead and bleed the brakes. Ultimately I really think I need E-Brake on this truck. What are my options, just new calipers? Thanks!
My build thread: '66 Chevy |
09-05-2022, 01:07 AM | #2 |
Re: Is this a non E-Brake caliper?
Yes.
An e-brake caliper would usually have a lever of some sort that mechanically applies the piston. Usually a mechanical (not hydraulic) ebrake is a DOT requirement. Does the kit come with hardware for a wee drum inside the rotor hat?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
09-05-2022, 08:50 AM | #3 |
Moderator
I think what your looking for is a 1985 Eldorado Toronado Riviera rear caliper with E brake for that bracket.
09-05-2022, 11:01 AM | #4 |
This is the mid=90's Z/28 Caliper, you can see the lever on the bottom. I doubt they fit your bracket though.
09-09-2022, 01:08 AM | #5 |
Sorry for the late reply, thanks for the info! I think I'm on the right track now for new calipers.
09-09-2022, 09:15 AM | #6 |
A pinion mounted e-brake might be a better option.
Here’s an example. https://www.speedwaymotors.com/Ford-...oke,44784.html |
09-10-2022, 10:41 AM | #7 | |
Moderator
