Old 01-04-2004, 01:37 AM   #1
walker
walker's Avatar
A/C mounting
The A/C is down on my truck due to the wreck a couple of months ago and the compressor leaks too, so I was wanting to rebuild the system. The only thing I realy don't like about it is the compressor mounting bracket. It is the one on the passenger side that bolts to the exhaust manifold, over the valve cover and on to the intake. Is there another mounting system I could use with this or another type of compressor that is a little nicer? I have newer heads with accessory holes in them if that helps.
BTW I have a '67 C-10, short W/P, power steering, with a 350. Thanks.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 01-04-2004, 08:36 PM   #2
walker
walker's Avatar
Anyone???? ttt
Andy,Phx AZ
"23 C-Cab-sold
'70 MG B.-sold
Old 01-04-2004, 08:55 PM   #3
Gee_Emm
There are 2 or 3 different styles
Gee_Emm is offline   Reply With Quote
Old 01-05-2004, 12:32 AM   #4
rage'nrat638
rage'nrat638's Avatar
allen grove makes brackets for s.b. engines...
i have one using a sanden comp.
rage'nrat638 is offline   Reply With Quote
Old 01-05-2004, 02:47 AM   #5
PR454SS
PR454SS's Avatar
Those are a nice set-up, can't use them if your headers don't turn down though, found that out the hard way and I had already powdercoated em'.
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 01-05-2004, 11:20 PM   #6
valley 67
valley 67's Avatar
if you go to sanden suction fitting from compressor is #10 size fitting where original fitting from evaporator is #12 so you would have to modify hose to get to work and also most sanden compressors cycle with a binary or trinary switch where as a-6 uses poa valve and never cycles clutch.
valley 67 is offline   Reply With Quote
