Old 10-04-2022, 08:17 PM   #1
burnem
Frame swap 64 2wd C20 long bed to a 71 C20 frame
what are the problems in mounting a 64 GMC cab, nose, and 8' bed onto a 71 or 72 Chevy frame? or is it easier to add front disc brakes and power steering to the 64 frame? all opiniones appreciated, thanks
burnem is offline   Reply With Quote
Old 10-04-2022, 08:30 PM   #2
karlbenz
Re: Frame swap 64 2wd C20 long bed to a 71 C20 frame
I would never frame swap for disc brakes. Lots of info on here about it
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 10-04-2022, 09:59 PM   #3
AcampoDave
AcampoDave's Avatar
Swapping disc and power steering are pretty straight forward on the earlier frame. I know some GMC trucks had rear leaf springs and I could see that being one factor for swapping the frame, but aside from that it would be easier to swap the front crossmember and get a power steering adapter such as those made by Captian Fab. If you have a donor lined up your already on your way. Don't overlook the rear end too because the donor may possibly have a more favorable gear ratio.
AcampoDave is offline   Reply With Quote
Old 10-04-2022, 10:20 PM   #4
Warrens69GMC
Warrens69GMC's Avatar
I had considered getting a 64-66, so I have a complete rolling c20 chassis from 1976.
Still haven't got my 64-66 though.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-04-2022, 11:27 PM   #5
cwcarpenter98
cwcarpenter98's Avatar
Definitely easier to swap over the front suspension since the front crossmember is almost a bolt in with just drilling a couple holes. The cab on the later frame requires modifying the cab mounts and you run into issues with the front bumper and frame horns not matching up correctly
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-05-2022, 09:11 AM   #6
SCOTI
SCOTI's Avatar
Front frame horns are shaped different so changes are required depending on bumper used.
Front radiator core support mounts are in a different location.
Rear cab mounts are in a different location.
Definitely easier to swap disc brakes & power steering over to a '64 chassis.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
