10-08-2022, 04:46 PM | #1 |
Brake vacuum
I have front disks, rear drums with power brakes and an automatic transmission I recently installed a new motor with a more lumpy cam. I checked my vacuum at the hose that comes out of the back of the carb and at idle it fluctuates between 10 and 12. When I drive around normal it works fine but my parents house has a vary steep driveway and when I am backing out I am not able to bring it to a full stop until I hit the bottom. Is that enough vacuum. If I remember correctly 12 is a good amount.
10-08-2022, 05:59 PM | #2 |
Who Changed This?
Re: Brake vacuum
You mean at the bottom of the driveway, not the pedal goes to the floor (bottoming), right? Is your foot constantly on the brake pedal, or are you on and off of it? With low vacuum, the engine may not be able to pull it fast enough and you can lose the assist if you are pumping it, even a little.
10-08-2022, 06:18 PM | #3 |
Re: Brake vacuum
Should I assume that you feel that 10 to 12 is not enough vacuum?
I meant when I hit the bottom of the driveway. I am holding it constant not pumping it. The break peddle is bottoming out at this point but not on the floor it just hits a hard spot. |
10-08-2022, 06:29 PM | #4 |
Re: Brake vacuum
So I just saw on the summit website that it should read around 16-18.
10-08-2022, 06:57 PM | #5 |
Who Changed This?
Re: Brake vacuum
So I guess your vacuum is too low for that booster. You may have to install a vacuum pump. That must be one rumpty cam. Is the booster single or double diaphragm?
10-08-2022, 06:57 PM | #6 |
Re: Brake vacuum
14hg of vacuum should be enough.
You need to increase your vacuum. A couple ways to do it. A vacuum pump or fine tuning your carb and timing. If you close your throttle completely your vacuum will increase. Then to get it to idle you’ll need to increase your initial timing. What carb? What’s your initial timing at? Where’s your vac advance connected to? |
10-08-2022, 07:29 PM | #7 |
Re: Brake vacuum
My engine is currently detuned for the breaking in process. I need to go another 200 miles before I can adjust the timing for better performance. It sounds like that might help increase vacuum.
12-02-2022, 09:10 PM | #8 |
Re: Brake vacuum
Have you finished the breaking in and fine tuned your motor with more initial timing?
12-02-2022, 10:07 PM | #9 |
Re: Brake vacuum
You can use manual brakes just fine. I was running disk in the front and drums in the back with 15 inch rims but changed to 20 all the way around and now it will not stop at all in a panic stop. I have an aggressive cam with 8 inches of vacuum and a vacuum power brake booster calls for 14 inches. So I purchased a right stuff hydro boost kit to cure the stopping problem. Few more days until it gets here.
12-02-2022, 10:47 PM | #10 |
Re: Brake vacuum
12-03-2022, 08:36 PM | #11 |
Re: Brake vacuum
I checked my timing today but made the mistake of forgetting to plug the vacuum advance.
16 degrees of initial timing. 33 at 1500 Around 55 at 2500 Blueprint recommends 32-34 at 3500 (or at the point the mechanical timing stops advancing) for their engines. I didn’t feel comfortable taking it up to 3500 rpm It was running at 600 rpm at idle which seems a little low so I bumped it up to 7. The brakes are so close to working good. I think the semi metallic brake pads and boots with a vacuum canister will solve the problem. |
12-04-2022, 11:37 AM | #12 | |
Re: Brake vacuum
New pads and brake shoes won’t change how your brakes function.You still won’t have enough vacuum for your booster. |
10-08-2022, 08:03 PM | #13 |
Re: Brake vacuum
How much vacuum do you have at 1000 rpm?
10-08-2022, 08:12 PM | #14 |
Re: Brake vacuum
According to the people at Master Power Brakes, 18” at idle is the number you need, can you get by with less…sometimes…..
10-08-2022, 08:45 PM | #15 |
Who Changed This?
Re: Brake vacuum
Right? Maybe leave it in neutral and coast down that steep driveway? I've never run a big enough cam that I didn't have vacuum-assisted power brakes work properly. Though now that I think on it a bit, those cars didn't have power brakes.
I know! Spin a doughnut and head down hill going forward! What could go wrong? My dad used to get so ticked off if one of us burned rubber in the driveway or the street.
10-08-2022, 09:01 PM | #16 |
Re: Brake vacuum
In neutral or just hot foot it.
Hot foot it still gives you control if you need it. |
10-08-2022, 11:30 PM | #17 |
Re: Brake vacuum
Going down in neutral sounds like a good idea. It should help. It is a little dangerous. I will check to see what the vacuum is at 1000 rpm next weekend. My tools are not in the same place that I live.
10-10-2022, 09:30 AM | #18 |
Re: Brake vacuum
What motor are you running? What are some of the specs of the cam and motor?
10-10-2022, 10:34 AM | #19 | |
Re: Brake vacuum
https://blueprintengines.com/product...ads-roller-cam |
10-17-2022, 10:32 PM | #20 | |
Re: Brake vacuum
Denver/Big Island -- Instagram: Slammed66c10 '46 Fleetmaster Coupe '64 C10 on Ridetech Air Ride '66 C10 on GSI Bagged Chassis - in progress '12 FLHR '11 Custom Homebuilt Chop/Softail |
10-17-2022, 11:12 PM | #21 |
Re: Brake vacuum
10-17-2022, 11:26 PM | #22 |
Who Changed This?
Re: Brake vacuum
Elevation variation will yield less boost when the atmospheric pressure is lower, so at your elevation, you're pretty much getting the full benefit of that. Something else must be going on with your braking system.
10-20-2022, 10:05 PM | #23 |
Re: Brake vacuum
Not sure on the vac. I was getting 11inches with a 600cfm holley (from blueprint) on the same motor you have.
I believe I lose a 16% loss in HP due to elevation. Best, Jon
10-10-2022, 10:44 AM | #24 |
It's Better With Nitro
Re: Brake vacuum
This is the meme I used to send to my friends who insisted I run a vacuum booster on my build, since I'm still thinking of putting a 6-71 supercharger on mine:
In all seriousness, I would probably do away with the vacuum booster if you plan to keep your engine. It's those low speed, in-traffic situations that you'll need the immediate brake response the most. I run a Wilwood MC (no booster) and their 6-piston caliper up front with 4-piston Mark Williams disc brakes out back. Driving in our SoCal traffic, I'm thankful for the instantaneous brake response.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
10-10-2022, 11:05 AM | #25 |
Re: Brake vacuum
"do away with the vacuum booster if you plan to keep your engine".
Do you mean that using a booster will damage the engine or do you mean that I will have to make the decision between my brakes working (while using a booster) or changing the engine? I think my next step is to wait and see how much vacuum I end up having after the engine is properly tuned and then start changing things if I am still not getting enough vacuum. |
