Old 10-17-2022, 12:04 AM   #1
AcampoDave
AcampoDave's Avatar
Looking for a quality 4" rear drop spring
I used to get my springs from Early Classic Enterprises and they were always great, spot on, exactly as advertised. Now I'm helping a friend try to find a true 4" drop rear spring and reviews of competitive brands are all over the map. CPP has a "heavy-duty and a standard duty, Mcgaughys springs are said to be "soft and produce lower than desired drops and LMC....is LMC...enough said. Anybody have a recommendation for a true 4" drop rear spring like ECE used to sell?
https://www.performanceonline.com/19...-Coil-Springs/ what about these, at least we know they are made in USA .
AcampoDave is offline   Reply With Quote
Old 10-17-2022, 07:24 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Looking for a quality 4" rear drop spring
I have those on my truck, I like them.
Old 10-17-2022, 11:45 PM   #3
theastronaut
theastronaut's Avatar
Have you considered air bags with schrader valves instead of springs? That's what I'm using on my '66 to get around the inconsistent spring height issue, and still be able to haul a lot of weight when needed. I used D2600 bags with upper cups that mount using the stock holes so no mods to the truck were needed.
theastronaut is offline   Reply With Quote
Old 10-18-2022, 12:50 PM   #4
Arne
Arne's Avatar
I'm pretty certain the PO used POL springs in my '64, since all the rest of the chassis parts are obviously POL (sway bar, panhard rod, shocks and probably the short bed conversion kit as well). Seem to be decent parts in general, although since I don't know for certain what drop he ordered—or how much the real drop was since I never saw the truck prior—I can't speak for the accuracy of the claimed drop amount.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 10-18-2022, 08:15 PM   #5
62bagger
62bagger's Avatar
I bought 4" rear drop springs from the truck shop. This is where it sits after the install.
62bagger is offline   Reply With Quote
Old 10-19-2022, 12:48 AM   #6
SidsChopShop
I have the CPP heavy duty 4” springs on my daily driver ‘66. They ride good and still have enough support to haul things in the bed. The only downside I can say is the coil windings are much tighter than stock or other brand drop springs. They are so tight it is very hard to even slide an open end wrench into to hold the spring cups making installation or taking them off the trailing arm a PITA!
Here is my truck 2/4 drop with 255/70/15 rear tires.
Edit: Admins could someone fix the upside down photo?
SidsChopShop is offline   Reply With Quote
Old 10-19-2022, 09:26 AM   #7
SCOTI
SCOTI's Avatar
Rotated....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-19-2022, 10:45 AM   #8
bigmoe
bigmoe's Avatar
I used 97-06 Jeep TJ rear coils for a 4' drop. AC Delco 45H2104 variable. 653lbs.
bigmoe is offline   Reply With Quote
Old 11-15-2022, 11:15 PM   #9
AcampoDave
AcampoDave's Avatar
We ended up going with the American made ones from POL. They were just right so they get a thumbs up. Thanks to all who responded
Old 11-16-2022, 10:36 AM   #10
72Mountaineer
72Mountaineer's Avatar
Any other changes to the suspension when using these springs? Shocks, panhard bar, etc.?
72Mountaineer is offline   Reply With Quote
Old 11-16-2022, 05:35 PM   #11
bigmoe
bigmoe's Avatar
I used the CPP rear panhard #6572DTBK. It's longer than stock, adjustable and the bottom attaches at the perch. I have a squarebody rearend that lacks the integrated attachment point on the axle housing so attaching at the perch was a must. The longer length will give you less side deflection as the rear travels up and down.
Old 11-16-2022, 09:05 PM   #12
AcampoDave
AcampoDave's Avatar
We put a Chinese made shock relocator kit from Amazon. The grade 5 hardware sucked with cheesey lockwashers but the brackets seemed decent. Oh, and we bought KYB shocks from LMC.
Old 11-16-2022, 10:56 AM   #13
SCOTI
SCOTI's Avatar
Be sure to follow-up w/some before & after images for future reference.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-16-2022, 09:34 PM   #14
AcampoDave
AcampoDave's Avatar
Sorry, no pics today. The problem was it had 5" rear drop springs but it was on the bump stops. The 4 inchers gave it just enough free travel to provide a comfortable ride. I know some guys will shave the bumpstops and all that, but in this case we're trying to build a longer distance driver suited for a variety of conditions so practicality was the big factor in raising it up. We changed from a 4.5ラ5 to a 2.5ラ4. Removing the 2 " drop springs in front but keeping the 2.5 inch dropped spindles and swapping 5" drop springs in back for 4 inchers.
