Old 10-27-2022, 06:12 PM   #1
mi396ss
Saginaw 3 speed to Transfer Case Adapter
I have a 1972 K10 that has a Saginaw 3 speed in it. I pulled the transfer case and transmission and I am wondering how you get the adapter separated from the transmission? I took off the 5 bolts holding it to the transmission but it will only come back like an inch. Any help is appreciated.
mi396ss is offline   Reply With Quote
Old 10-28-2022, 06:22 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Saginaw 3 speed to Transfer Case Adapter
I would like to see that! Pics?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-28-2022, 10:28 AM   #3
Accelo
Accelo's Avatar
Just guessing here but it my be like the 4 speeds and you will have to pull the tapered pin from the reverse lever. This will allow the slider to pull loose from the gear.
Having never seen a 4 wheel drive three speed this is just a guess and I could be full of it.
Most manuals I have worked on were 4 speeds.
Cheers
Accelo is offline   Reply With Quote
Old 10-28-2022, 02:58 PM   #4
mi396ss
I figured it out. It’s actually a Muncie HD 3 speed and not a Saginaw. I rotated the adapter and was able to see a circlip in there that needed to be squeezed. I’m all set. Thanks.
FYI. I’m guessing this was kind of rare but this K20 had this Muncie 3 speed backed by a NP205. There isn’t a whole lot of info out there on these.
Old 10-29-2022, 05:11 AM   #5
jjzepplin
jjzepplin's Avatar
Pics!!!!!
Old 11-07-2022, 06:53 PM   #6
mi396ss
Here is a picture of it with the adapter. I can’t get them back together now, not sure what I’m missing here.
Old 11-08-2022, 06:35 AM   #7
jjzepplin
jjzepplin's Avatar
That sure looks like a car style 3 speed. I bet you could pop a 4 speed in there. I've never seen one. That must be rare. COOL!
Old 11-08-2022, 07:28 AM   #8
I knew the 3spd was standard but never saw a 3spd K/20. I had a 3spd '71 K/10 with NP205 but never had that apart. The 3spd K/5s coupled to a small transfer case, maybe a Dana 20?
Old 11-08-2022, 09:25 PM   #9
mi396ss
That’s what this is, 1972 K10 with 3 speed backed by NP 205.
Old 11-09-2022, 09:46 AM   #10
my04
my04's Avatar
'72 k10 SWB 400sbc 3 speed Muncie
I remember having the same issues as you are.
The adapter is a tight fit and the bolts will draw it in if you tighten them evenly, a little antisieze helps too.
It's actually a very heavy duty transmission except I hate the non syncronous 1st gear.
1966 Custom Camper -327, 3OTT
1968 Chevrolet K20 - 350, 4 speed
1972 K10 SWB - 400, 3OTT
2003 Corvette Z06 - LS6 350, 405HP
2004 Tahoe LT
2015 Silverado 2500HD - 6.0L V8
my04 is offline   Reply With Quote
Old 11-09-2022, 06:00 PM   #11
mi396ss
That’s it. Ok, thanks. I’ll try using the bolts to get it back together. Any idea what it’s worth?
Old 11-09-2022, 08:30 PM   #12
my04
my04's Avatar
Parts for these aren't easy to find, it doesn't neccesarily mean its rare or valuable but you don't come across these trannys everyday either.
I do keep an eye out for them just to have as a spare. My guess or hope would be under a $100.
2004 Tahoe LT
Old 11-09-2022, 08:46 PM   #13
mi396ss
Ok thanks.
Old 11-10-2022, 09:20 PM   #14
57taskforce
All about them K’s
57taskforce's Avatar
Thanks for posting pics up! My dad had a 71 K10 30+ years ago that had the same setup, before he swapped a 465 in it. You don’t see them very often in the K trucks.
Tyler
