Active Member
![]() Join Date: Jan 2016
Speedo Cable and speedo gear box
Hi everybody.
I know there's been several posts on speedo cables not working and some are from years ago, but I wanted to get a fresh perspective on this. The speedometer on my '72 C20 had bounced sporadically in the past and I bought some Cable-ease to grease it and see if that solved the issue. I opened the end at the back of the speedometer and pulled the cable all the way out, lubed it, and slid it back in. Upon doing that, the needle doesn't bounce or even move now. I noticed the end of the cable at the trans is sorta squared. Does that need to be seated properly in the speedo gear box? How about at the back of the speedometer in the cluster? Is there propery "seating" that should be done? Since the speedometer stopped moving altogether, I went down to the trans and pulled out the nylon gear at the gear box thinking maybe it was all work, but it looks fine. Do I need to get the to line up properly in the trans? if so, how do I do that correctly? It's set a ways into the trans housing that I'm not sure the right way to line it up. So, that's where I'm at. If anyone has any suggestions, I'd really appreciate it. Thank you.
Re: Speedo Cable and speedo gear box
Yes the square end of cable needs to mate (go into) with the female square base of speedo and plastic speedo gear in trans
Active Member
Got it. Thank you. I'll take a closer look at it and make sure it's all seated properly and test it out.
Active Member
So, the cable is mated with the gearbox, but how in the world would I know for certain if I got the plastic speedo gear lined up with the trans? I can put the plastic gear in and spin it with my fingers until I feel in jive with the trans but the moment I attempt to place the speedo box back or any movement for that matter, I misalign them. The plastic speedo gear isn't all chewed up, but would the gear in the trans be? I'm not sure how to check it, I guess.
![]() Join Date: Feb 2016
It's been my experience that you can turn the cable end at the speedometer end back and forth until it drops into the gear in the transmission.
The cable is supposed to be perfect sized so the cable fitting at the speedometer won't thread on completely if the cable hasn't slid into the end of the gear. I am assuming your transmission is a T400?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#6 | |
Active Member
Were you trying to put the gear in the trans without the gear housing? The housing itself automatically lines the gear up in place. I dont understand how you dropped the gear inside the trans? Get a piece of wire form a hook and fish it out. The tail shaft housing isnt that deep
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
You would need to use a flashlight or probe camera to see the drive gear inside the trans.
If you just put the driven gear in the bullet and slide that in, the teeth should just mesh or you may slightly just need to twist the bullet some until they do. Then put the speedo cable in end of bullet, after you secure bullet with the one hold down bolt & metal tab If the driven gear has been changed to one with less teeth do to a rear gear swap or tire size change...it "may" be just 1 tooth to small and no longer engaging the drive gear given, if I understand correctly everything worked before you pulled cable, I suspect you just don't have the speedo cable engaged in either speedo or trans. For me they have always basically fallen in place when I have worked on cable or gears if cable is good and engaged and driven gear is good the only other reason for no work is either the drive gear is messed up or the gear inside speedo is. Usually you would see chipped teeth on driven gear if drive gear was bad |
#9 | |
Active Member
Posted via Mobile Device |
LNP is correct, the tailshaft housing isn't that deep. Unless the gear slid quite a ways forward, you should be able to pull it out with a piece of wire.
I believe there should be a clip that holds the little gear in place. You may have to pull the tailshaft off eventually to replace that clip. Driving the truck with the gear inside would be your call. There's not really anything inside the housing that would chew up that little gear if it's just laying on the bottom. Here's a thread showing the area with the tailhousing removed. |
#11 | |
Active Member
If you are going to drive with the driven gear just laying inside the tail shaft, put the bullet back in and the speedo cable in so you don't puke tranny fluid driving
You can try and fish it out...but I suspect you will need to drop tailshaft which will drain all your fluid also shiat happens, not a big deal, just work to get the tail shaft off. Get new gasket. You could just RTV it...but that is not what I would do when you put the driven gear in, put it in the bullet first then slide the bullet/gear in |
Actually if you think about it driving it even with the gear housing and cable in place it will push fluid out and up the cable housing into the speedometer. The driven gear seals the housing by a seal in it that the gear shaft goes thru. The seal should have held the gear in place but as said sh#t happens. If he cant get it out where it is I would have it towed. But I would put the housing and cable in place to minimize fluid loss.
Active Member
Whelp, I think the best way to go about it will be to pull the driveshaft and the extentsion cover and fishing it out that way. I'm glad Indyuke posted the link to the other thread showing what it looks like.
What parts should I replace whilst I'm in there? Bearings, gaskets, etc?
#15 | |
#16 | |
Active Member
#17 |
Active Member
Well, update on the nylon speedo gear. I've retrieved it from the tail housing on the trans and got the drive shaft back in. Drove it home from work, still nothing on the speedo or the odometer. So, a car buddy of mine mentioned I could take the end off the gauge itself, and see if it's spinning as I drive it. I'll see if I can't tape a zip tie to the end of it and watch it spin?
#18 |
![]() Join Date: Sep 2001
Yes this would be an easy test, if you can lift a rear wheel you could do that test without driving, which might be easier to see the cable end.
#19 |
You wouldn't even have to start the engine doing it this way. Just have a friend or a kid turn the wheel while you check the cable.
#20 |
Active Member
Thanks to everybody for all the valuable input. On Sunday I put a drill on the speedo cable at the trans end and gave her hell. The wife said the needle was needling and the odometer was odometering. So, it's gotta be something in the speedo gear box or on the shaft itself. None of the teeth on the nylon speedo gear were chewed or worn and the driven gear looked all good. The clip holding the driven gear was in place as well. I've found through forum links a replace speedo gear sleeve housing but not the whole gear box itself. Should they be any movement at all on the speedo gear box when it's installed and fastened down? What I mean is, when it's bolted it good and tight, I can wiggle the whole gear box as the cable housing on the speedo cable allows. I imagine that should be all tight and snug. Now that the white devil (snow) has spread across the land, I'm not driving the truck until spring. Ugh. I'll have to keep at it. Thanks again everybody.
#21 |
Yes, nice and snug it should be. Could you share photos?
#22 |
![]() Join Date: Mar 2015
You can reuse the gasket on a THM400. If you want to add a little sealant that's fine also.
Just pull the driveline and the 6 bolts on the tail housing and retrieve the speedometer gear. No trick to reinstalling the housing. I typically install the gear after the housing is installed. Easy to inspect the gear when the housing is off. Just grasp the plastic gear and be sure it doesn't turn on the shaft. Only light hand pressure is all that is needed to prove it isn't loose. Cheers |
#23 |
Do you have this style of speedo gear housing?
has anyone done any mixing and matching of speedometer drive parts? With that style of housing you have to have the correct housing for the tooth count of the driven gear. It also has to be clocked correctly in the hole. Meaning turned so the tabs on the hold down clip are on the notches on the housing. That orients the housing so the gear properly meshes with the drive gear. I've never had any real trouble getting the end of the cable to go in the driven gear but have had to turn more than one to get it lined up. usually you can do that at the bottom when you are trying to line them up. You just turn it a minute amount and gently go again. Make sure that the cable is routed smoothly from the trans to the speedometer. Sometimes we try to get it in too tight of a bend and it wants to bind up. I've seen that both in cables that were too long and ones that were too short.
#24 | |
Active Member
#25 |
Mr48 is on to something - I recall now having the exact problem and it was caused by the wrong housing. I had a 39 tooth gear (brown) and I had a housing for 40-45 gears.
Its easy to test this gear when you have the speedo cable off and the driver side rear tire lifted off the ground, truck in gear, you can turn the tire with your foot and watch the gear turn. You can push your finger against the end of the gear to create resistance on the gear to confirm its turning under resistance. In your case the gear definitely isn't turning, and the housing could be the reason. |
