Old 11-01-2022, 06:36 PM   #1
Johnl48
Hydroboost question
Converting to a hydroboost system. Mounted on the firewall it angles down pretty dramatically. Is this normal for these or am I missing something. Everything in cab lines up with pedal
Old 11-01-2022, 07:23 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Hydroboost question
mine doesn't angle down drastically, will take a picture tomorrow, Phillies are on shortly
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-02-2022, 07:53 AM   #3
Joyridin
Mine doesn't look like that at all. It points straight out and lines up with the pedal. That might play a bit of havoc with the master cylinder depending on which one you use.
Joyridin is offline   Reply With Quote
Old 11-02-2022, 08:14 AM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Judging from the mounting plate it's supposed to angle down a bit. What did that unit come off of? Maybe take it off and rework that plate to make it flat...?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-02-2022, 10:36 AM   #5
jaros44sr
jaros44sr's Avatar
16673995746948392596414014788329 by James Jaros, on Flickr
My is level, must be in the mount, if you need some machining done PM me, you're not far away
SAFETY FIRST
AS usual, off topic
Jim
Old 11-02-2022, 10:39 AM   #6
jaros44sr
jaros44sr's Avatar
16673998653796338265152678591138 by James Jaros, on Flickr
Sorry blurry pic
SAFETY FIRST
AS usual, off topic
Jim
Old 11-07-2022, 10:51 AM   #7
6600DURAMAX
6600DURAMAX's Avatar
JAROS44SR - what bracket are you using that mounts the hydroboost to the firewall - looks to be billet...??
thanks
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 11-07-2022, 03:37 PM   #8
Johnl48
thanks
Not sure. Someone gave it to me. I guess I have to get a flat plate bit the nut is hard to get off. Don't have the socket
Old 11-07-2022, 07:24 PM   #9
jaros44sr
jaros44sr's Avatar
thanks
Yes it is billet ,bought the whole system from Hydroboost, but it does look like you can build one, if you have Bridgeport
SAFETY FIRST
AS usual, off topic
Jim
Old 11-08-2022, 10:15 AM   #10
MARKDTN
[QUOTE=jaros44sr;9139976]16673995746948392596414014788329 by James Jaros, on Flickr
Not to hijack the thread, but what system are you using to go coil on plug TunedPort? I have several TPI systems and I love them. Might convert one of them to this.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 11-08-2022, 12:08 PM   #11
biketopia
You could use an EFI Connection front cover and then you'd have to figure out engine management either with a 411PCM conversion or aftermarket ECU. On my SBC, I use a Holley Dual Sync distributor and a dominator ECU to control my throttle body and LS coils. Any of Holley's ECU's (Dominator, HP, Terminator X or X Max) are capable of running the TPI and a dual sync or the EFI Connection cover, would just need the right wire harness.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 11-08-2022, 08:32 PM   #12
jaros44sr
jaros44sr's Avatar
[quote=MARKDTN;9142162]
FAST XIM, COILS are LS, but had to make mounts on valve covers, the coil near firewall has to be angled, and i had custom wires made by Taylor
16679541796644954224432166538350 by James Jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 11-09-2022, 08:07 PM   #13
v30crewcab
v30crewcab's Avatar
the earlier astro ones sit level. the later ones are angled. don't know the actual year of the change though.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 11-02-2022, 12:36 PM   #14
Bigdav160
Bigdav160's Avatar
I'm using the factory bracket/linkage
It slopes down slightly not like the op's
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-07-2022, 01:17 PM   #15
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I'm running the Astro van setup and it doesn't angle down. Not sure what setup you are running.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-07-2022, 10:26 PM   #16
dagnabbitt
dagnabbitt's Avatar
Mine
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
dagnabbitt is online now   Reply With Quote
Old 11-07-2022, 10:34 PM   #17
jeffahart
jeffahart's Avatar
It looks like it's upside down. I think the install should be with the accumulator on the engine side; and master pointing slightly up.
j
White K20
jeffahart is offline   Reply With Quote
Old 11-07-2022, 10:35 PM   #18
dagnabbitt
dagnabbitt's Avatar
Originally Posted by jeffahart View Post
It looks like it's upside down. I think the install should be with the accumulator on the engine side.
j
Bingo, I think
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 11-08-2022, 12:24 AM   #19
57taskforce
All about them K’s
57taskforce's Avatar
j
This is definitely true. Here’s mine.
Tyler
Old 11-08-2022, 10:03 AM   #20
Joyridin
j
Dang...never noticed that and I have my accumulator on the outside like his set-up to clear the valve cover!
Old 11-08-2022, 11:22 AM   #21
Thealien
Thealien's Avatar
It will work either way. Certain mounting plates will dictate the orientation. Personally, I do not like the lines coming out the top so mine is mounted with the fittings on the bottom. I bought mine from Hydatech Braking with the mounting plate attached designed for bottom lines.
Old 11-08-2022, 12:05 PM   #22
jeffahart
jeffahart's Avatar
Absolutely, with the caveat that if you are doing a GM swap and want to do minimal modifications it will need to be installed factory like...
Hydra tech seems like a good company, how to like their products?
j
White K20
Old 11-08-2022, 01:35 PM   #23
Thealien
Thealien's Avatar
j
Other than the long lead time I like the product and their communication. It has only been driven around the shop yard as it went right to the body shop after it was moving under its own power. It seemed to work in the parking lot? I am also running 14" front and 13" rear Wilwood brakes. It "should" stop well!
Old 11-08-2022, 01:14 PM   #24
Joyridin
You just take a file and make a new slot in the mounting plate to flip the booster. Took about 10 minutes.
The benefit of having it mounted with lines coming out the top is you can usually use some of the factory lines depending on your application. Had I not flipped the unit, I could have used 2 factory lines.
Old 11-08-2022, 01:31 PM   #25
Thealien
Thealien's Avatar
Since it came from Hydratech braking with the mounting plate attached in the correct orientation there was no need to file. It installed the way I wanted with the lines down. This went in my 2-wheel drive LS3 blazer, or I would have gone with using something factory stock including lines. Mine are all AN
