power steering conversion kit
Who sells the best, most complete, easy to install power steering conversion kit? For my 1965 C-10 2 wheel drive pickup. Part numbers if you have them, whose did you use? Thanks
![]() Join Date: Sep 2022
Re: power steering conversion kit
I'm interested in this as well. I'm waffling between a normal power steering conversion or going whole hog with a power rack & pinion. Looking forward to some replies.
I'm planning to use Speedway Motors part #91015019 in my '65, unless somebody has a better option or if someone has a horror story about the Speedway Motors kit.
https://www.speedwaymotors.com/60-66...ox,462210.html John
1965 C10 Long Bed Fleetside SBC 350 and Saginaw 4 Speed Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=838676 |
#4 | |
#5 | |
https://www.speedwaymotors.com/D-R-C...ne,119433.html I don't know if Speedway would be willing to sell the kit without that part, but you could certainly source the pressure line elsewhere. I'm probably a year away from doing the power steering on my truck, so I've got time for the supply chain to sort itself out. If you're ready to move forward now, you may have to buy the kit components separately and find a pressure line somewhere else. Obviously, that's not an ideal solution, but at least you would know that the major components would all work together.
Anyone else??
#8 | |
Another option is going with the Volvo electric power steering pump. You can mount the pump anywhere on the vehicle.
#10 | |
Thanks. John
It can go with a power steering box.
Google searches will come up with several discussions on the swap. It's a big modification with the drifting crowd. Here are a few that I've bookmarked:
https://www.corral.net/threads/volvo...te-up.2499503/ https://www.forabodiesonly.com/mopar...racuda.486613/ https://forum.studebakerdriversclub....-pump-in-stude |
Moderator
![]() ![]() Join Date: Aug 2011
Do you have a V8?
#15 |
Yes 350 Chevy
#16 |
Has anyone tried a Prius electric steering box? Might be better than the electric pump. Looking at all options.
#17 |
That's the route I was headed in before looking at the Volvo pump. Nobody makes a bolt in kit, you'd have to buy the motor and parts and figure out where to put it inline in the steering column. Also you can not have anything other than the steering shaft in the column, so that eliminates an automatic or manual shifting on the column. It will only work with floor shift.
#18 |
The column mount electric assists still leave you with a worn out, slow ratio steering box. Swapping to a 70's/80's power steering box gets you power steering and a quicker steering ratio so you don't have to crank the wheel three full rounds to park.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#19 | |
Also, the quality of most readily available parts store rebuilt steering boxes is really poor these days. Use a new CPP box, or a rebuilt box from a company like RedHead Steering Gear to make sure it works as it should.
#20 | |
And a plus for the electric options is that you still have power assist even if the engine stalls. Last edited by Arne; 11-08-2022 at 04:03 PM. Reason: typo |
#21 | |
My suggestion is you go back to your shop where you can pretend it's still 1974. Enjoy your truck with no radio, defroster/heater fan, windshield wipers (unless you're running a vacuum system), etc... BTW - I'm doing an engine swap, putting in "gasp" a Chrysler 331 Hemi. The fact is that they don't make a bracket for power steering because back in 1954 Chrysler incorporated the power steering in with the generator as one unit. I don't want to use a generator, I don't want to spend $1200 having a generator converted to an alternator. HotHead Hemi does make a P/S pump bracket... but guess what, it doesn't fit on the 331. I have three choices... manual steering, Electric Power Assisted Steering, or go with a remote electric steering pump. What's your solution? Go with manual with the 31x10.5 tires on the truck? Last edited by 61hawk; 11-07-2022 at 08:05 PM. |
#22 | |
My 1954 331 isn't an extended bell housing, it's currently mounted to an A727. |
#23 |
[QUOTE=61hawk;9142353]Why fab up something when a better solution is already available? I have a new P/S box (OEM not rebuilt) and I can tuck the pump away where it's not seen.
I like this idea, any pictures of the electric pump mounted? |
#24 | |
[quote=jibs;9142517]
I got mine from Pull-A-Part for $35 for the pump and bracket (you want to grab that because it already has the rubber isolators and is basically a cradle for the pump. |
#25 |
![]() Join Date: Sep 2006
This is a bolt in unit. The hardest thing to do will probably be hooking up the steering column. https://www.summitracing.com/parts/u...gaAtlAEALw_wcB
This is the kit from POL https://www.performanceonline.com/19...caAjPMEALw_wcB
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
