11-04-2022, 10:38 AM | #1 |
Blew up my rear diff - need rear end ID help - 1970 K10
So I was going down the road about 40 and BOOM, rear differential decided to start trying to eject metal pieces through the housing.
I'm trying to read posts as fast as I can to figure out what I have and what I need but having trouble identifying...here are some pics. What rear end do I have? All I have to go on so far is I've got a 1970 K10 with 3.07 gears, and this number on the axle TDG0313W and this number on the carrier 3896839 and this hole in the pumpkin!!! |
11-04-2022, 10:54 AM | #2 |
Re: Blew up my rear diff - need rear end ID help - 1970 K10
Found this great post by LockDoc with axle decodings... based on the axle number I have it appears to confirm that this may be the original axle to the truck? Or at least same year?
http://67-72chevytrucks.com/vboard/s...hlight=3896839 |
11-04-2022, 01:09 PM | #3 |
20' Daredevil (Ret)
GM 12-bolt. That's a beautiful truck!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-04-2022, 01:27 PM | #4 |
Welcome aboard! Wish it was under better circumstances.
Where are you and that great truck located?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-06-2022, 06:19 AM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
GM Truck 12-bolt Positrac, excellent rear end and gear for a daily driver. Hopefully the carrier and posi survived. Those T-12's were used in 1/2 ton C/10's until 81. If you cant find a 12-bolt you can upgrade to a Dana 60 or 14-bolt with factory No Spin or Detroit Locker.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 11-06-2022 at 06:36 AM. |
11-06-2022, 11:44 AM | #6 |
I own an identical Transmission Jack. Didn't know they made the attachments you have for the differential. Likely handy for transfer-cases also.
If it was me I would replace the assembly. After this stress things are likely bent! Sounds like this is your goal. I will qualify this as I have seen amazing repairs with epoxy metal. Mostly when replacement parts were unattainable. If you pull the cover a picture of the carnage would be interesting. As for the interchange, do the K truck (4x4) have different axle widths like the two wheel drives? Do any of them match the width of the K trucks? Obviously to use one out of the more common 2 wheel drive trucks it would have to be equipped with the rare leaf springs option, if it's a Chevrolet. Or from a GMC where, they all have leaf springs. Nice truck. Differential only lasted 52 years! Did you put it in four wheel drive and drive it home like I may have. Differential was already dead. Can't hurt it much. Cheers |
11-06-2022, 04:03 PM | #7 | |
All about them Ks
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s Last edited by 57taskforce; 11-06-2022 at 04:16 PM. |
11-07-2022, 08:14 AM | #8 |
Now's the time to ditch those 3.08/3.07 pair and put in 3.73 gears
11-07-2022, 11:57 AM | #9 |
Thanks for all the help so far...will post pics of the destruction when I have.
I'm in the Fort Lauderdale area. Any suggestions on where to look for a donor rear end? Willing to travel to get it. Or ship. Yes my preference would be to do a simple direct swap and not modify. I don't mind the expensive list of internal parts - like you said, it would be nice to know for sure what's in there. But having trouble finding the right housing...looking all over on craigslist, FB, etc So what I'm seeing is I need to find a GM 12 bolt rear from a 69-72 K10 as a 2WD leaf spring axle won't work without modifying mount positions. Is a 4WD GMC 1/2 ton axle also a direct bolt in? Last edited by 34GH111; 11-07-2022 at 03:31 PM. |
11-07-2022, 12:44 PM | #10 |
I'm seeing that the 73 and later K10 axles have a wider spacing on the leaf springs, is that correct?
11-08-2022, 08:23 PM | #11 |
All about them Ks
Yep that is correct the only 73-87(91) rear axle that has the correct 67-72 perch spacing of 40.5 on center is from the 77+ K30.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
11-10-2022, 10:10 PM | #12 |
So what about 70-71 blazer axles? Are they a direct swap in for the K10 (leaf and shock perches)? Have a line on one and waiting for some measurements...
11-07-2022, 09:23 PM | #13 |
Yes, the frames are the same width, but the frame spring perch brackets are bigger.
As I recall the wheel mounting surface (WMS) (think drum face to drum face) is a bit more making the overall track width a bit larger. BTW, I think I saw a for sale post for a 70 K10 diff here today. |
11-08-2022, 10:26 AM | #14 | |
Thanks - will look back through the parts classifieds and see what I missed. Thought everything I found was old/already sold. |
11-10-2022, 11:08 PM | #15 |
All about them Ks
Awesome! Yep a 69-72 blazer axle should be a direct fit.
