I installed the heavy-duty light harness from LMC.(could have been a bit longer as wire doesn't stretch) and when I turn the lights on they both appear on the yellowish side, more so on the passenger side. I am just taking a stab at the problem but leaning toward bad grounds even though all three are newly drilled so contact should be ok. Any ideas would be greatly appreciated as it is friggin cold out there. Going directly to the problem would save frostbite from setting in. I hope your day is trucking along just fine and the sun is shining. Thanks in advance. Ron
#2 | |
The Older Generation
Re: I need some help with the headlights.
I'm not familiar with the LMC harness. Does the new harness use the headlight relays in the system? LockDoc
#3 | |
![]() ![]() Join Date: Jul 2002
And I agree, I would have liked another inch on the wire length. It was tight, but it was long enough.
LockDoc thanks for the reply. The harness came with the relays as Palf70Step replied in his answer. I'll try with the direct ground as Sheepdip suggested. Just maybe something might be simple in my life for a change. Thanks all and have a nice day. Be good as He's comin eh!
![]() Join Date: Nov 2018
Quick test for a bad/poor ground is to run a ground wire with proper clips from your battery ground post to your grounding connection, if it rectifies the problem it's a grounding issue.
Make sure your core support has a good ground to the frame/battery. Folks tend to remember about grounds everywhere but somehow overlook the coor support.
The coor in core support is probably the reason for the lack of professionalism Ha. That's a good point as when the truck was painted it was done in pieces, so the painter covered everything really well including bolt holes. I just got back from shopping as I do have to eat, but I'll make sure to check the grounding out. If one didn't have to maintain a certain level of health and tidiness what would we ever do with all that spare time on our hands eh? Have a good one.
Zee problemo is fixed, and the problem was me. I did the ground check and went over everything a thousand times and finally it dawned on me. It was the dielectric grease that I used. In my growing up part of life more was better. More chickens net more eggs, more cows net more milk so naturally I applied that to the connectors. WRONG, as the grease is a nonconductive substance, so I was killing the power and I guess the grounding process by smearing the stuff on like chocolate icing. Learned my lesson. Go cheap on the grease and put your bucks into chrome. Now to tackle a night drive, spooky eh! Thanks for the encouragement as it spurred me on.
Glad you figured it out. My coworker always says” if a little is good more is better”😂
The real lesson here is you found it, rectified it, and learned not to repeat the mistake in the future.
OP
Good you figured it out. I also put in the LMC headlight harness and for me it was plug and play. I had no issues with the length of any wires. My truck has also been painted and all panels, core support, fenders, etc were pulled and painted. I use star washers for the ground connection points on the core support for each of the head lights If your headlights are the stock ones (3200k) they will be "brighter" as will all your lights as the 12v load for the headlights is now off the switch. If you want a "whiter" headlight, get the Silverstar Halogen in the 5600k version. Most auto part stores carry them and of course Amazon |
