Old 01-05-2004, 02:40 AM   #1
1974StepSide
Play it Loud...
1974StepSide's Avatar
Question What is the "Normal" operating temperature?
I installed an autometer temp. gauge today. My factory gauge hasn't worked since I've had the truck.
I also replaced the Thermostat with a 195 degree unit.
When I went for a test drive to check if the gauge was working, it went up to about 210 at it's highest and stayed a little lower after that.
At what point is boil-over? At what temp should I be concerned that things are getting too hot?
What temp. do you run at on "normal" days?
Big Moe
1974 Cheyenne Super Stepside, 350/400, Hooker Headers, Flowmaster Mufflers... Needs new doors, fenders, hood, and paint.
1952 Chevy Pickup waiting to be brought back home!
1974StepSide is offline   Reply With Quote
Old 01-05-2004, 03:03 AM   #2
Russell
Professional Grade
Russell's Avatar
Mine has four ticks, dunno what the temps are, but it usually sits 3/4 of the way to the first tick.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-05-2004, 03:05 AM   #3
1972C10
1972C10's Avatar
water boils at 230 i think but water and antifreeze boils at like 260 maybe? i could be wrong thou. Ive got a factory gauge that registers 210 with a 195 degree thermostat .
1972C10 is offline   Reply With Quote
Old 01-05-2004, 04:54 AM   #4
silverado_ss03
silverado_ss03's Avatar
i wouldn't know, my factory guage doesn't work.
silverado_ss03 is offline   Reply With Quote
Old 01-05-2004, 05:00 AM   #5
allthrtl
Available for Adoption
allthrtl's Avatar
The temp that water boils at sea level is 212º F. Now, in an automotive situation, the more pressure the water is under, the higher the boiling point, don't have the specifics here in front of me, but you get the picture. Also, the coolant you add to the system also raises the boiling point.......
Anyway, I run a 180º thermostat and my guage stays about 187-190º most of the time. A really hot day in traffic it will easily get to the 200+º mark, but I need a bigger radiator.... So, I guess 205-210º is about right for that thermostat...I don't know what the climate is where you live but, I never go above a 180º thermostat in my arrid climate.....
HTH
Michael
1983 C10 SWB 2001 Silverado SWB 1995 Corvette
allthrtl is offline   Reply With Quote
Old 01-05-2004, 05:15 AM   #6
crackajacka
Stylin
crackajacka's Avatar
i run a 170 thermostat and i run 180 -190 regaurdless unless im really pushing it like 80-90 on my th350trans. when i shut my truck off the temp rises to 200-210 depends on how hot it is outside
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 01-05-2004, 11:35 AM   #7
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
mine shows 210 allday long.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 01-05-2004, 02:04 PM   #8
Tom
driving is in my blood
Tom's Avatar
My facotry gauge stays at the 1/4 way mark which I've decided is about 175*. With the 160* thermo in it would be right below it at normal temp. In 110* AZ days at 80mph for an hour it will get to the half way mark [about 210* or so] I put a 180* thermo in for the winter and it sits just above the 1/4 mark now at normal temp. And this is with a 3 core radiator and high flow water pump.
Old 01-05-2004, 02:06 PM   #9
PHOENIX
I also have autometer gauges (and love them )
I have a stock 350 with 4-core rad and 195 thermostat.
I also run a dodge/jeep factory electric fan for v-8 engines.
Most the time the fan isnt on.
Even when the fan is on it acts the same as far as temp changes and low/max readings).
First thermostat cycle of the day it gets up to around 210 degrees then lowers down to 170 or so. After the first cycle its anywhere between 180 and 195. You can actually watch the needle go from 180 up to 195. Right when the needle hits 195 it drops right down to 180 and starts over again.
If I shut the truck off and come back out in a minute or two then it gets up to 220 degrees.
The gauge is accurate and shows all temp changes, you really cant ask for more.
I replaced my thermostat this weekend along with a few other things and noticed the reading got up to 230 or so before the thermostat opened up for the first time. After that "break in" it was acting the same as before. I suggest you keep the 195 thermostat.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 01-05-2004, 03:42 PM   #10
bigblock73
yeller
bigblock73's Avatar
Mine never went above 200...usually stayed between 185-190 all day long.
That was with a 3 row radiator, 190 thermo (I think), and a clutch fan.
bigblock73 is offline   Reply With Quote
Old 01-05-2004, 05:06 PM   #11
1974StepSide
Play it Loud...
Thanks for all the input guys, I knew I could count on getting the info I was looking for!
Big Moe
Old 01-05-2004, 08:17 PM   #12
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
water boils at 212 degrees when you put the pressure cap on it you allow the water to get hotter before it actually boils my trucks run at about the first mark on the guage and i havent a clue what temp that is when i change the thermostat ill check the book and see whats recommended and use that prolly 195 degree.
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-06-2004, 12:06 AM   #13
86SILVERADO
86SILVERADO's Avatar
205 to 210 for me with a 180 thermostat and a 350 with a three row.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 01-07-2004, 01:16 AM   #14
apstguy
LED King
apstguy's Avatar
My 305 has never gone above 200. That is with the stock gauge - not all that accurate but it works. It has creeped to 210 after the choke got stuck on on the freeway. It dieseled when I shut it off at that temp.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 09-02-2019, 08:58 PM   #15
thrtsxchambers
thrtsxchambers's Avatar
Re: What is the "Normal" operating temperature?
Bringing up an old thread but I need more info on this. I have a 388 in my 83 c10. 3 core radiator, 165 thermostat and dual electric fans. At idle it hits around the 210 mark on the stock gauge. I shut it off before letting it get any higher and let the fans run for a minute after shutting it off. Any input if that temp is ok for that motor? I do not have the overflow tank installed yet, not sure if that would make a difference. I haven't driven it yet to see what it reads while driving.
thrtsxchambers is offline   Reply With Quote
Old 09-02-2019, 10:02 PM   #16
74CustomK20
74CustomK20's Avatar
Pull the stat and sticker in a pot of water with a thermometer. See if it's working right. If it is (assuming cooling system parts are new) I'd look at your rad being too small or something is plugged somewhere.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 09-03-2019, 04:28 AM   #17
TrailerTrash
TrailerTrash's Avatar
Verify the actual temperature with an infrared thermometer
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 09-03-2019, 06:57 AM   #18
Dead Parrot
I wouldn't worry too much based on temps reported by a 36 year old gauge. Quite possible the sender in the motor isn't matched to the gauge in the dash. Several threads on that issue.
2nd the suggestion on an infrared thermometer.
Could also buy a new aftermarket gauge and install the sender in the opposite head or in the intake. You could just leave the 2nd gauge in the engine compartment or laying on the cab floor until you are satisfied that the dash gauge is reading correctly.
Keep in mind that the stable running temp for a t-stat is 10~20 higher then the listed temp. The listed temp is when it starts to open.
Dead Parrot is offline   Reply With Quote
Old 09-03-2019, 03:29 PM   #19
DieselSJ
For those of you who want to know the relationship between pressure and boiling point -
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 09-03-2019, 05:15 PM   #20
blindbug
I just spent labor day weekend dealing with replacing a busted water pump. 350 with a stock (or at least a direct replacement) radiator, 50/50 coolant. We flushed the rusty coolant with the waterhose from both the radiator and the heater core. Replaced the upper, lower, and heater core hoses, replaced the 190 themostat with a 180 and replaced the water pump with a carquest brand. Drove the truck 3 hours in 90 degree weather and never cracked 190 the whole way, going 60+ (with a high speed of 79). Might have got near or slightly over 190 when I hit a half hour traffic jam due to a wreck. This, on a 1976 350, which MAY have been rebuilt at one point in its life (but not during my ownership). Sending unit is a Dakota Digital with DD gauge set, so should be fairly accurate.
Just some food for thought on the running temps in these old trucks.
blindbug is offline   Reply With Quote
Old 09-04-2019, 12:18 PM   #21
SCOTI
SCOTI's Avatar
Airflow through the radiator impacts temps.
Water pump condition impacts temps.
Thermostat range impacts temps.
Coolant passage conditions impact temps.
Gauge location impacts displayed temps.
Several variables to consider.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-06-2019, 04:43 PM   #22
thrtsxchambers
Everything is brand new, even the temp gauge since I broke the stock one 2 days ago. I haven't been able to check it again. I hope to drive it this weekend and see how it goes.
