12-09-2022, 06:24 PM | #1 |
Rear suspension is jarring when hitting bumps
1960 GMC 1000 series.
New POL rear coil spring, standard ride height Shocks - replaced about 5 years ago, but they might not be correct New POL adjustable trackbar (panhard bar). Whenever I hit a bump (even small potholes) the rear suspension hits HARD and is quite brutal. The only thing I can think of is that the shocks are underpowered or too short and not able to dampen the rebound from the new coil springs? Anyone have an good recommendations for rear shocks for these trucks if we think that is the issue? Thanks for any ideas. |
12-09-2022, 08:07 PM | #2 |
Re: Rear suspension is jarring when hitting bumps
Can you tell us the current model # of shock currently on it?
12-09-2022, 08:17 PM | #3 |
12-10-2022, 03:03 AM | #4 |
Sounds like a shock problem.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
12-10-2022, 01:54 PM | #5 |
Pull the two lower shock bolts out then bounce the truck to see if the shocks are too stiff.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-10-2022, 02:12 PM | #6 |
Or if the shocks are too short, and top out hard on rebound.
12-10-2022, 08:13 PM | #7 |
08-19-2023, 06:05 PM | #8 |
So, it seems the rear shocks that were on there were too short.
60-62 GMC and Chevrolet's don't usually have rear shocks listed at all the usual places. I found one posting that pointed towards some Race Car Dynamics Bilstein shocks that fit (Part 55-R148) . The before and after is quite noticeable. Thanks all for the responses and suggestions! |
