LS upper radiator neck on water pump....
does the upper radiator hose neck on the top off the water pump interfere with the throttle body actuation?
If so, how do you get around it/ fix it? I'm thinking using either the Summit or Holley fabricated intake and 92mm throttle body. RIZ ![]()
RIZ ![]() 81 C10 short box 82 K5 Blazer Last edited by riz; 12-10-2022 at 07:05 PM. |
Re: LS upper radiator neck on water pump....
Pick of my 98 wrangler with DBC. Truck FEA. Truck intake.
Pick of my Nova with DBC. 2002 Camaro FEA. LS6 intake. I would buy LS "style" radiator with the inlet and outlet on the passenger side of the radiator. Makes routing the intake tube easier. Pic of my latest 80 Camaro project. |
LS Short Box - on you Camaro can you supply the part numbers for the rubber 90 and then the aluminum tube ? Super clean setup
thanks
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
I don't have the part numbers but on my LS swaps I buy intake stuff from intakehoses.com. They have a huge selection.
The Camaro has a blade style mass air flow sensor because it's a LS3 that you can't see on the bottom of the intake tube. Pic of my 68 C10 intake. The engine is a 2002 LS6 so it has a mass air sensor right after the air cleaner. It's kind of like right behind the radiator cap. |
