Old 01-05-2004, 11:17 AM   #1
5150
C10 Club Tennessee
5150's Avatar
How do I lower my Truck?
Okay, I need you guys to talk to my like I'm an idiot about all this, because I am. I bought some 4 inch lowering springs for the front. What's a good (cheap) way to lower the back. Also how much do I lower the back. I just want a good stance. I have coils all the way around. Do I need different shocks? Can I use blocks on the rear even though I have springs?
Thanks,
Bryan
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 01-05-2004, 12:07 PM   #2
PR454SS
PR454SS's Avatar
You will have to get some lowering springs for the back also you should be able to pick up a set cheap enough, you can also use blocks and springs together for the rear, I dropped mine four in the rear wth springs and it wasn't quite enough so I added a 1" block also. just make sure you get the adjustable panhard bar so the rear axle will be centered properly. You will also have to get some new shocks that are valved right for less travel.
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 01-07-2004, 02:10 AM   #3
pphatbasstard
pphatbasstard's Avatar
I thought that 3" was a low as u can go in the front with springs?
pphatbasstard is offline   Reply With Quote
