1971 2wd to 4wd conversion build
Saved a '71 burb from an early death as a "Crew cab" donor body a few years back.
Now, doing a 4wd / LQ9/4L65E conversion. Sourced a 8" lifted '70 4wd 'burb chassis that was modded to fit a LWB truck. Unf*cking it so 'burb body fits back on it was step one, and rebuilding everything. Last edited by C130Nav; 01-05-2023 at 12:17 AM. |
Re: 1971 2wd to 4wd conversion build
Drivers side rocker/floor. Very clean
Roamed the backroads of northern AR
3rd door rocker repair
Passenger door rocker repair
Its a Truck Thing......
I will be doing a conversion on a Longhorn. Got all my parts from a 72 Burb 4X4 that is getting beefed up.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
Smitty,
The rear body mounts are different in truck VS. 'Burb. I'm looking for 4wd 'burb body mounts for the #4 position(above the front leaf spring mount) forward of the rear axle. Since you won't be using them when mounting the Longhorn bed, I'll buy them from you when you remove them. Let me know Last edited by C130Nav; 01-04-2023 at 09:57 PM. Reason: Added info |
Pass rocker complete; rotted cowl spot repaired. Damn critters...🤣
Glad you saved that. Looks too clean to have been cut up for a crew cab. I like the direction that you are taking this. Will follow along for sure.
#10 | |
I was saying I was converting a 2wd Longhorn to 4WD with a suspension from a 72 Burb. I'm using the Longhorn frame and it is already leafs in the back. The whole front with mounts came off the Burb. My buddy is doing a conversion and I will see what brackets he is not using. Smitty
Been a few weeks since last worked on the truck.
Got the section between 3rd door and rear wheel replaced. Just the outer panel was swiss cheesy. Patch panel fit reasonably well; but lower contour was more curved than original. Had to make some relief cuts to make it match 3rd door rocker contour. |
Sandblasted and painted inner quarter area. Relief cuts on front of patch made it line up with rocker nicely. Welded up patch, ground it down flush, ready for a skim coat to blend in the two panels.
BlahBlahBlah
Keep the pics coming Nav, looking good so far!
![]() Join Date: Jan 2003
Good job!
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
#15 |
Spent some "nasty time" on my back with a pressure pot sandblaster, doing some underfloor cleanup. Still need to get under there and touch up some areas again this week, but looking pretty clean so far.
#16 |
More underfloor cleanup; qtr panel rot on pass side behind 3rd door; and pass floorboard all cleaned up.
#17 |
The Older Generation
That thing still looks pretty clean. It would be nice to find one like that around here.... LockDoc
#18 |
![]() Join Date: Feb 2016
Great work! I for one are very glad you saved it.
I'm pretty sure Flynavy30 will be following your progress.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 01-11-2023 at 02:02 PM. |
#19 |
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice burb you saved and nice rust repair work! On the 4x4 swap, did the 2wd e brake cable mounts interfere with your shackle mount positions?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#20 |
#21 |
More rust repair work done. Driver's side rocker panel. Luckily the inner rocker didnt need anything other than a good sandblasting, and a few pinholes welded up. Front and rear of new rocker needed some massaging to fit; but overall an easy job.
#22 |
Front part of left quarter panel repaired. Had to weld a patch for inner quarter. I'm really amazed at how much dirt gets packed up inside these rockers and quarter panels. Not sure how it makes it's way inside, but it sure gets in there.
#23 | |
Rocker is looking good. My Panel Truck is starting to rust in front of the rear wheel wells and has some dirt, mud, and other junk packed in there. I'm not sure how it gets in there either but I need to get it cleaned out. LockDoc
#24 |
BlahBlahBlah
How is this project coming along?
