01-07-2023, 01:52 PM | #1 |
Under dash courtesy light question
I am rewiring my truck with American Autowire kit and I was hoping to see how some of you mounted the courtesy lights that come with the kit. Here are pictures of what I have. If you can post a pic of yours installed, I would appreciate it.
Thanks! John
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
01-07-2023, 03:55 PM | #2 |
Re: Under dash courtesy light question
good question... have he same kot... subbing
1967custom |
01-07-2023, 04:26 PM | #3 |
All about them K’s
Here’s how I did mine. My dash was already dimpled for the holes. I just used the self tapper screws that were included in the aaw kit I got. (Courtesy lights only)
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
01-07-2023, 06:42 PM | #4 |
Pretty much same mounting, multi chip Led makes a world of difference. About $10 for. 10
33 chip 1156 bulbs
01-07-2023, 11:33 PM | #5 | |
01-08-2023, 12:34 PM | #6 |
Those LED bulbs won't cause any problem because they don't draw as much voltage? If I use LEDs for turn signals I need a different flasher, correct?
01-08-2023, 09:54 PM | #7 |
No issues with led in applications that do not require flashing. Just remember they are polarity sensitive and have to be connected correctly to work.
01-09-2023, 02:28 AM | #8 |
As said in previous post no issues that do not require flashing. 69-70 front side markers do not flash. 71-72 they do. Problem is because front side marker grounds through the bulb to make them flash. If you install led in front turn location of 71-72 the front sidemarker will not light.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-09-2023, 02:43 PM | #9 |
70+ ( Old Skool Club )
i bought a kit from a board member Roger Koop and here is the mounting. If you have the door switches then its plug and play.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-09-2023, 02:52 PM | #10 |
As they look.
01-10-2023, 11:38 AM | #11 |
01-10-2023, 07:00 PM | #12 |
Subbed for future reference
