01-09-2023, 03:36 PM | #1 |
1970 C10 ChassisFab Build Thread
I will be sharing my 1970 C10 ChassisFab suspension build thread. It will be a longbed to shortbed conversion. 350 rebuild, th350 rebuild. Bagged and bodydropped. 22/20 setup with Billet Specialties Suave rims. Here are some pics so far.
01-09-2023, 03:40 PM | #2 |
Re: 1970 C10 ChassisFab Build Thread
Frame was wire wheeled and stripped down. Keep in mind the goal of this build is to be "budget" minded. Here is the longshot fabrication short bed conversion kit. It lines up perfect. All of my structural welds will be done by a mobile welder. I don't have a 240v outlet in the garage.
01-09-2023, 03:50 PM | #3 |
Here is the ChassisFab rear suspension. Just need to cut the frame and install the panhard bar. The rear diff won't be welding in until I get the tranny/driveline angle established.
01-10-2023, 07:29 AM | #4 |
Looks expensive and extensive!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
01-10-2023, 06:30 PM | #5 |
01-12-2023, 12:38 PM | #6 |
More pics of the rear. Installed the panhard bar and cut the C notches in the frame. Take it easy on my welds they are just tacked in place
My 1970 C10 ChassisFab LWB to SWB Build Thread |
01-12-2023, 01:31 PM | #7 |
Proprietor of Dale's Corner
Looks good, moving along nicely.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-17-2023, 04:35 PM | #8 |
Got the front suspension mostly mocked up. I am having some trouble determining how to measure the correct caster angle of the spindle before I mount the A-Arm perches in place. Any tips on this would be appreciated.
Got the bolt-on body drop pieces mocked as well. I will use lock nut hardware for these. Since my crossmember is pancaked 2", I will need to raise the steering parts all 2" up. This will require a notch in the bottom of the frame to clear the pitman arms.
01-31-2023, 06:17 PM | #9 |
Hubcaps came in
02-01-2023, 06:41 PM | #10 |
Grease fittings installed for all the poly bushings
02-03-2023, 12:05 PM | #11 |
Rebuilt the gauge cluster a bit. I got a new clear lens and a temperature gauge. I then repainted the needles with needle gauge paint. I also painted the gauge case in white to hopefully make the LED bulbs reflect brighter. I think this a cheap way to get nice looking gauges without buying a complete new set.
04-24-2023, 06:27 PM | #12 |
Got the bolt-on body drop pieces mocked as well. I will use lock nut hardware for these. Is this a complete kit or are some parts homemade? Did it come from PF or other? How much does it lower the body? Thanks. |
04-24-2023, 07:47 PM | #13 |
The bolt on body drop is from Stone Custom Fab. It lowers 3/4". For the rear bumper I just drilled the holes 3/4" lower. It doesn't come with bolts though so I just bought Grade 8 hardware.
04-26-2023, 11:03 PM | #14 |
Got a remote battery jumper installed so the frame won't be stuck on the ground if (when) the battery dies.
05-08-2023, 03:34 PM | #15 |
Tear down and rebuild of the non-tilt column
02-03-2023, 10:38 PM | #16 |
Nice work so far! I'm in to see how this turns out.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
02-13-2023, 08:21 PM | #17 |
Got the frame painted with POR15. Made an absolute mess spraying it but it sure does look nice. Now it's time to reassemble and begin with brake lines, fuel, air, etc.
02-14-2023, 11:17 AM | #18 |
It looks great! I'll be doing the same frame treatment this spring.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-17-2023, 04:12 PM | #19 |
Finishing up on the frame! Lots to do still but making steady progress. I used an external trans cooler and made up a couple of brackets to mount it under the frame. It should help clean up under the hood some more for a super clean look.
Also I'll be sticking with some Woodyears until I can find a set of Centerline smoothies or a similar wheel. Sucks they discontinued them.
03-17-2023, 06:39 PM | #20 |
Boy, those two quality control inspectors look like they are a little tough to work for. Nice job!
03-18-2023, 07:32 PM | #21 |
They keep me on my toes! They love all the parts boxes lol
03-27-2023, 07:07 PM | #22 |
Air lines and bags installed, as well as steering linkage. Next task is brake lines.
Getting ready to move on to body work. I will start with the bed floor and get it raised on the frame (mainly to get some garage space back).
04-24-2023, 12:10 PM | #23 |
Heck yeah this is looking awesome! I love the shot of the license plate to ground clearance. I would go with the true Chevy orange. The other color is too red. I never really figured out which color was used on which cars/trucks, but to me the more orange color looks better in our trucks.
04-24-2023, 03:06 PM | #24 | |
05-08-2023, 08:29 PM | #25 |
just read your build thread nice really nice work @ light speed compared to me being stalled Im getting in the passenger seat of this build
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
