![]() Join Date: Mar 2014
Seasoned Patina Guys: what do I do?
Going back together on the interior to the cab, and I have the dash out, ready for reinstall. But I plan on painting the outside (driver facing) of the dash in a semi gloss clear, what do yall normally do to the backside? I'd hate for the rust to continue, should I clear coat it to seal it or do the work to put an actual sealer on it? This will be a year round driver.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
![]() ![]() Join Date: Sep 2008
Re: Seasoned Patina Guys: what do I do?
This is what I use. I spray it on everything inside and out if it has rust.
https://www.lowes.com/pd/LOCTITE-Rus...da8a878d6e0563
#3 | |
![]() Join Date: Dec 2009
You just (Cost) and saved me Some money. ![]() I got a case of it I will pick up tommorrow. ![]() ![]() ![]()
Just remember that the radio and other pieces ground thru their mounting to the dash.
What would you suggest? I know Im clearing the exposed part of the dash, but the rear of the dash, what would you do? Im fine with leaving it natural if you dont think it would be an issue, just want to know what the experienced guys do.
#6 | |
Before you clear the top of the dash, try using the Extend. It leaves a finish that doesn't look "fake". Just scuff with a pad, wipe it down and spray it on.
#7 | |
![]() Join Date: Apr 2013
This is what I use.. works pretty good..
https://www.amazon.com/POR-15-45818-...00MBFOHEW?th=1
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
I am not sure. I was just pointing it out so when you put it all together you don't have to chase grounding issues. Those are not fun. Normally I just leave under the dash alone on mine pending that they aren't super flashy with rust. Or add a ground block and ground things using separate wires.
Another great rust treatment I've been using a long time is Permatex Rust Treatment spray. Both Xtend and the Permatex can be painted directly. I use it alone on all my rusty metal signs outside. There are many products out there but many leave oxidation crust that must be dealt with.
Tags |
dash, paint, patina |
