01-13-2023, 03:18 AM | #1 |
Adding a clock to 70 dash
It looks like the 73-79 clock or the 81-87 clock can be retrofitted into the 70's style C10's.
They differ in the placement of the knob used to set the time. Both are available aftermarket. I am planning on installing one into my truck but am wondering which on works best for the transplant. I am including pictures of both below; Early 73-79 has the time reset on the top of the clock. |
01-13-2023, 04:30 AM | #2 |
Re: Adding a clock to 70 dash
Prefer the factory vacuum gauge or air pressure gauge myself in in the blank location. Both pictured would require drilling the lense. I would wager that the one to left with the adjustment knob closer to the center would be a better choice to avoid interference with the dash bezel. If you want a clock Dakota Digital has a nice instrument cluster with a clock in the factory tach position.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-13-2023, 09:34 AM | #3 |
For the cool factor - buy a 70's era clock that sits on your dash - some have a magnetic back and can be put on he dash.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-13-2023, 09:37 AM | #4 |
I have this one I was going to use but plans changed , tin ready to build a tic toc / tach cluster , new clock and wiring new chrome knob ,I have a used lens with it to use to mock up before you drill your good lens , I can list it on the parts board if your interested ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
01-13-2023, 11:09 AM | #5 |
Grumpy;
That would be excellent. I will watch for it on the parts board. Cheers. |
01-13-2023, 12:43 PM | #6 |
I have done this before. It's a slick mod like what might have been done from factory, as seen in cars and the next design of trucks. I'd rather see an engine gauge added under or on the dash, which is also an era correct thing. I haven't been doing clocks in the dash, though, since carrying a cell phone. No need to wear a watch, either. A clock in the dash is a touch of luxury car in your truck
01-13-2023, 02:13 PM | #7 |
I don't have a pic handy but I retrofitted the "QUARTZ" clock out of a square body years ago.
AND DO NOT DRILL! On this message board years ago somebody suggested taking a nail, lock it in a vise grip, heat it up with a propane torch or whatever you got handy, then melt a hole for the knob. Worked like a champ. Slickest idea ever. I fear cracking 50 year old plastic with a drill bit. One more note. I have my truck in an unattached building where I keep all my toys (Chevelles, boats, snowmobile, ATV, etc.) When I open the door I hear one thing. That clock ticks REALLY LOUDLY.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
01-14-2023, 01:51 AM | #8 |
Here are a couple I've done. One with a OE tach and quartz clock added. One with clock only. The quartz clocks are quiet. No ticks.
Jim Last edited by FirstOwner69; 01-14-2023 at 01:58 AM. |
01-14-2023, 10:48 AM | #9 |
Thanks everyone for the information and tips. I purchased Grumpy's setup. I have to pull my dash to replace the fuel gauge anyway. I have already installed the volt gauge. I just like the look of the clock. And yes I even wear a watch. I am not overly concerned if it even keeps time. But with quartz internals I suspect it might.
Question for FirstOwner69. Did you replace the temp gauges or somehow repaint the originals? The temp gauge is my only complaint as the red is faded on the temp gauge on my dash. Cheers |
01-14-2023, 02:41 PM | #10 |
Good info here:
http://67-72chevytrucks.com/vboard/s...d.php?t=524139
Jim Last edited by FirstOwner69; 01-14-2023 at 02:46 PM. |
01-14-2023, 07:31 PM | #11 |
I did something different. I added the vacuum gauge in the cluster and put the clock in the dash pad like this.
01-15-2023, 11:43 AM | #12 |
That's pretty cool! What is the clock out of?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-15-2023, 04:10 PM | #13 |
01-15-2023, 11:56 AM | #14 |
That is a floor clock without a console from a 67 or 68 camaro. I had the face changed from a kit brothers sells i believe so the lettering matches the gauges.
01-15-2023, 01:57 PM | #15 |
Nice work, it looks sharp.
01-15-2023, 05:35 PM | #16 |
The clock i bought was a 67 camaro floor clock and I took the face off this clock kit and swapped clock faces. When I bought this kit it was considerably cheaper than it is now. https://www.cjponyparts.com/clock-co...RoCAdMQAvD_BwE
