![]() Join Date: Apr 2016
parking brake cable, conduit fingers
In the rear drum brakes where the parking brake cable enters the brake shoe and lever area, I am showing a close up picture of the fingers the conduit grips the entry hole with. I would like to remove a good cable from one truck and install it in another truck that has a bad cable assembly. I am reading the Haynes manual what it says about these, and I can't find mention of them in the Chevy service manual or Chilton's manual. Haynes says to compress the conduit fingers and withdraw the cable assembly. It sure sounds easy and I did this job once before about 5 or 6 years ago and I don't remember having difficulty then. Is there a trick to compressing the conduit fingers, preferably all at one time, and then the cable assembly will come out?
![]() Join Date: Dec 2013
Re: parking brake cable, conduit fingers
Use a hose clamp to compress the tangs and it will slide out .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Dec 2009
Have you tried a small hose clamp?
low n' slo
![]() Join Date: Mar 2009
what I did was.....
use a flat head and a hammer and bang each tab in that you can see, on the other side is a hex nut that you can put a wrench on. turn it with a wrench until the next tang shows and bang that one in too until they are all depressed... then you can pull through. hose clamp sounds so much easier though lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
It ended up working with a hose clamp. I had to try several times. Thanks very much for those ideas.
There's the Lisle 40800 that works well.
72 C10 lwb fleetside -stock 350/350 combo |
Tags |
conduit fingers, parking brake, rear drum brakes |
