01-20-2023, 11:21 AM | #1 |
Hydroboost / Power Steering cooler line routing
Below is the hydroboost line routing that I found - where in this line routing would I stick a cooler? Thinking of the below stacked plate cooler.
Only the "red" colored lines need to be premade with crimped ends while the others can be standard AN fitting lines ?
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years |
01-20-2023, 11:49 AM | #2 |
Re: Hydroboost / Power Steering cooler line routing
what are thoughts on a filter assembly like this ? Is it needed ?
01-20-2023, 11:49 AM | #3 |
I have a power steering cooler on 2 vehicles (one with hydroboost and one without). I have the cooler between the steering gear and power steering reservoir (the return), which is low pressure.
01-20-2023, 03:40 PM | #4 |
If you go with using a cooler, I second the above. I am using a heat sink with hydroboost.
The lid is stuck on my jar of anti seize |
01-20-2023, 12:18 PM | #5 |
I have a similar set-up to yours but with a rack and pinion instead of the box. I can grab the lines even after driving on city streets for quite a while.
What is the need for a cooler? |
01-20-2023, 02:18 PM | #6 |
not sure the cooler is needed just thought about including it ahead of time. Also the filter since there is no filter that I know of
01-20-2023, 02:20 PM | #7 |
01-20-2023, 02:32 PM | #8 |
Cooler would go in the return, no need to add a filter and over complicate the system. Some 01-13? trucks have a PS cooler that fits on the core support. Is it needed, not really unless you're racing the truck, can it hurt, no, just another connection point to leak and item to fit under the hood. Braided -6 for example is usually rated about 1000PSI, that right at the edges of what a PS pump is capable of, and some exceede that. A braided hydraulic hose could be built and match the rest of the system pretty easily though.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
01-20-2023, 03:15 PM | #9 |
What is the pressure on the low side ( or green hoses above ) ?
I have a remote canister from CVF ( came with the PS pump and pulley setup, I'll check to see if it has a built in filter.
01-20-2023, 05:42 PM | #10 |
Motortrend says return side pressures are usually around 100 psi, but when the system is cold, it can spike to more than 200 psi for a few moments.
I think this all depends on the pressure your power steering pump is putting out. |
01-20-2023, 09:36 PM | #11 |
When I did the hydro boost in my Mustang I used teflon -6 SS line on the pressure side and standard -6 SS on the return side. The PS tank had a filter to take out "micro" bubbles. That was per the folks at Hydratech. Worked great. See pic.
01-20-2023, 11:46 PM | #12 |
All about them K’s
Definitely between the gear and the return on the pump. The cooler is pretty important for me, if you’ve ever had a hydraboost truck with big tires in a situation like backing a trailer in a tight spot during peak summer heat, or even off roading where you aren’t going fast and are turning the wheels a lot, power steering fade is a very real thing when the fluid gets hot. Remember if the steering fades so does the brake assist in this application. I’ve had both of the above situations happen on my ‘98 silverado with 35’s under it. Obviously not everyone is dealing with big tires or these other situations but my point is when the fluid gets hot things don’t work anywhere near the same, and we are talking about brake assist…
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
01-21-2023, 01:30 AM | #13 |
The Older Generation
Here is a routing diagram with the reservoir in the pump. The pump is an LSx style pump with 2 returns. I don't remember who posted it or I would give them credit..... LockDoc
01-21-2023, 04:55 AM | #14 |
Believe the recommended location with hydroboost is as 57taskforce indicated. That would be the blue line in LockDock's image. Using a newer pump on my LSA with remote reservoir and dual returns in my case and my cooler is getting installed in the steering box return line to the PSC reservoir. Remote reservoir feed to pump should always be downhill.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 01-21-2023 at 05:09 AM. |
01-22-2023, 02:14 PM | #15 |
To add to the confusion - went out and assembled the remote canister from CVF - its only has two ports.......... the diagram I posted earlier shows three ports on the canister. Am I missing something or do I need another style remote reservoir ?
01-23-2023, 07:54 AM | #16 |
Yes, you need to add another return port. I mentioned the PSC canister because they have one with 2 return ports. Some people T the return from the hydro and steering box together, but that is not recommended.
01-23-2023, 10:57 AM | #17 | |
Because the vehicle I took my system off of., was leaking all around the tee fittings.
01-22-2023, 02:15 PM | #18 |
My hydroboost unit as well - standard 2500 HD style
01-22-2023, 02:53 PM | #19 |
The system I plan to use has a two-port canister.
I got it out an Astro van from Pick and Pull several years ago. It is cold and raining here. I will try to locate it this week maybe? It had a tee in the lines. The closest diagram I can find on the net is this.
01-23-2023, 09:20 AM | #20 |
Thanks Getter Done - I didn't realize a "T" would work but make sense...
Joyridin - any clue why a "T" isn't recommended ?
01-23-2023, 06:48 PM | #21 | |
If you do put in a T, make sure the straight through portion of the T is coming from the steering box and the T side is coming from the hydroboost. This will help. |
01-23-2023, 11:46 AM | #22 |
As long as the return is sized appropriately and the tee is not a restriction I see zero reason it would cause issues. Much like the return in a fuel system, you want it sized big enough so there's no restriction which causes unneccisary pressure.
01-23-2023, 12:03 PM | #23 |
Might be best to go with a 8AN line size on those two hoses vs the 6AN - that should ease any restrictions I would believe
01-23-2023, 02:59 PM | #24 |
100%
01-23-2023, 03:20 PM | #25 |
All about them K’s
You can run a tee. GM did on the early hydraboost trucks. I’ve got one on my 72 K20 that uses the oe ‘72 pump with one single return. Make sure it’s a full flow and you’ll be fine.
