Old 01-24-2023, 12:41 PM   #1
Hart_Rod
Hart_Rod's Avatar
Engine stands
Are the big block and small block engine stands the same, except for the motor mounts (BBC = 3 bolt/ SBC = 4 bolt)? Just trying to verify. TIA
Hart_Rod is offline   Reply With Quote
Old 01-24-2023, 01:03 PM   #2
kwmech
Re: Engine stands
Where did you find a small block that is 4 bolt? Bolt spacing is identical small and big. From the back of the block to the engine mount center has always been 16'' with the same 3 bolt pattern
Old 01-24-2023, 02:05 PM   #3
Hart_Rod
Hart_Rod's Avatar
Re: Engine stands
There are 4 bolt holes, but only 3 are used. Here is a picture of them mounted. Also have a picture of the stands which have multiple mounting holes and the 3 bolt big block mounts. The reason I am asking this question is that I'm doing a LT swap into my 84. I'm using the Dirty Dingo LT swap mounts and they sent me poly mount bushings for the 3 bolt mounts (BBC) when they were supposed to send me the 4 bolt mounts (SBC). Instead of sending them back, I am going to buy new 3 bolt Anchor mounts if they will fit. I've talked to Dirty Dingo, but the guy I talked to is more confused than I am. Here are some pictures.
Old 01-24-2023, 09:27 PM   #4
kwmech
Re: Engine stands
I thought you were talking about the block. My bad
Old 01-25-2023, 09:07 AM   #5
Hart_Rod
Hart_Rod's Avatar
Re: Engine stands
No worries. I think I have it figured out.
Old 02-05-2023, 06:35 AM   #6
PowerdbyChevy79
PowerdbyChevy79's Avatar
Re: Engine stands
I've always used Pic #1 for all LS/LT swaps with Dirty Dingo mounts.
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 02-06-2023, 10:54 AM   #7
Hart_Rod
Hart_Rod's Avatar
Re: Engine stands
Originally Posted by Pontiac1976 View Post
On the small block 305/350 factory engines like long bed 1 piece drive shaft pic #3 is where it would be most times. Big block would be long bed 1 piece drive shaft #1. most time everyone does not put the 305/350 back in the right one then the drive shaft has a 1/2" more slop can be more prone to leaking on hill slop parking as time go on. ADD if your drive shaft is a little longer then then the #1 pic would not be as much of a problem.
Thanks!
Thanks. I'm using the Dirty Dingo mounts, but they sent me the Big Block poly bushings and I want to use them instead of sending them back (as long as they will work). So the stands will work with any of the motor mounts is what I'm gathering...
Old 02-04-2023, 06:05 AM   #8
Pontiac1976
Pontiac1976's Avatar
Re: Engine stands
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
