![]() Join Date: Oct 2012
230 or 350
I have a 66 c10 I am wanting to restore. I want to leave the 3 speed in it and have a 230 and a 350. Which engine should I use? I will sell the truck after I get it done but will drive and enjoy it some before that.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
![]() Join Date: Mar 2015
Re: 230 or 350
In the aggregate the truck will be worth more, when you resell it, with the 350 in it.
If the motor will be rebuilt, the cost for rebuilding each motor will be close to the same if there is a difference the 350 will be slightly less money. I wouldn't worry about the transmission, three on the tree, holding up. They are tough enough for a 350 with a reasonable driver. |
#3 | |
#4 | |
Re: 230 or 350
Yes, they can & do work fine under light load/acceleration. But, in my experience if there's enough traction & you mat the gas pedal, some 3spds will not be up to the task of surviving the resulting load. In my scenarios, two suffered catastrophic failures taking the internal gears, clutch set-up, & bellhousing along for the carnage ride. Both of these failures occurred when accelerating while rolling & not after dumping the clutch.
Re: 230 or 350
I am going to pull the head of the 6 and see it’s condition then make up my mind
Posted via Mobile Device |
Re: 230 or 350
A light duty driveshsft/ carrier bearing set up is easy to break with a 350 too
