![]() Join Date: Dec 2018
How hard is it to lift a 2002 S10?
Hi guys, just picked up a 2002 Chevy S10 4x4 extended cab 4.3v6 automatic.
Thinking of lifting it. How hard is it to lift one of these? Not really wanting a crazy high lift, just enough so I can put on some slightly bigger tires and have a little bit more ground clearance. And if anyone has pictures of there lifted S10 I would love to see them!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
![]() Join Date: Feb 2010
Re: How hard is it to lift a 2002 S10?
This is a 1999 s10 zr-2 lifted from the factory. You can buy lifted spindles and lift blocks for the rear will give you 2-2 1/2 inches. I personally would stay away from a body lift. You can also crank tbars up a little in the front don't go wild you won't like the ride. I rebuilt the frontend on this truck previous owner had t bars all the way up rode like an old wagon.
![]() Join Date: Mar 2015
I used to replace the front CV joints in lifted S10 Trucks and Blazers all the time.
Not trying to sway you in any way. Just be ready for the issues lifting creates. I think they look good lifted. |
Any opinions on running bigger tires?
Or should I just stick with stock tire sizes?
There’s some info on this on the Blazerforum. You can go a little bigger with stock wheels and no lift. Wider wheels with more negative offset might help prevent run, but then you’re affecting the scrub angle.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
