mirror placement
Could someone give me the measurements of screw locations of the stock mirrors for a 67? My truck was bondo ed up years ago and I can't find evidence of their location. Thanks in advance.
#2 | |
The Older Generation
Re: mirror placement
Here's mine. When you take the door panel off check inside the door to see if the mounting plates are laying in the bottom. Many people remove the mirrors from the outside and just let the mounting plates fall to the bottom of the door. You will notice that the passenger arm is longer. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-07-2023 at 12:21 AM. |
from the assembly manual
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
![]() Join Date: Jan 2009
That assembly manual leaves alot to be desired.
Yes it does, but I bet the people that needed to use them on the assembly line knew what everything meant. LockDoc
Thanks Leon.
On the manual, the .86 dimension is the most critical, but I can't tell what it is referencing. Apparently, it is a more stable point than the edge of the door....lol. I ordered both mirror arms and 2 mounting plates as I vacuumed the inside of the doors and cleared the drain holes when I first bought the truck. |
![]() Join Date: Oct 2020
I have bought new doors and didn't want to drill any holes in it, so I am going with a set of these...
#8 | |
I hope you have better luck with those than I do. I have those on two of my vehicles and they are pretty much useless.... LockDoc
#9 | |
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#10 | |
No problem. That is the trouble with almost all of the illustrations in the Assembly Manual. They are missing the most important starting point. LockDoc '
