Old 02-20-2023, 03:35 PM   #1
Bridgeman57
Bridgeman57's Avatar
1961 frame swapped identification help
Picked up a 61 longbed and frame has been swapped. DANA 60 in the rear which is a 3/4ton I believe. Can稚 I壇 the frame to order parts to save my life. Thanks in advance!
Bridgeman57 is offline   Reply With Quote
Old 02-20-2023, 10:51 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: 1961 frame swapped identification help
Got a picture of the front frame horns? I'm thinking it's probably a GMC frame because of the leaf springs and Dana rear. If it's a 6 lug rear, probably a Dana 44. That steering gear and front cross member under the radiator looks a lot like 67-72 stuff
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-21-2023, 09:09 PM   #3
cbeerman
See if you can find the B.O.M. on the Dana that should point you in the right direction
https://www.differentials.com/differ...ion-work-page/
cbeerman is offline   Reply With Quote
Old 02-22-2023, 06:42 PM   #4
Bridgeman57
Will take more pics when I get home. I tried looking for the BOM numbers when I bought it but could not find. Might have to wire wheel some more.
Also, still have drums in front. Not sure what year Chevy/ gmc switched to pads but that would narrow it down a bit
Old 02-22-2023, 08:31 PM   #5
Arne
Arne's Avatar
Disc brakes started in '71. So a '67-70 crossmember would be drum.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 02-27-2023, 04:38 PM   #6
Captainfab
60-66 Nut
I agree with Arne and CW Carpenter. That is a '67-'70 GMC frame.
