03-05-2023, 10:32 PM | #1 |
Kick panel vents leak
My kick panel vents have a slow stream of water leaking from them when it rains. How do I fix this? Thanks.
03-05-2023, 10:54 PM | #2 |
Re: Kick panel vents leak
Would guess the drain holes at the bottom of cavity are plugged and they are filling up with water. Remove the flaps and reach in to get as much debris out as possible. Flush out with a hose through cowl until water flows out bottom.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
03-06-2023, 01:24 AM | #3 |
I had a truck so plugged it took a shop vac about 20 minutes per side to get all the crap out of them. You'll have to get creative with a stiff coat hanger or something similar to loosen the stuff up before it is empty. That's what I had to do anyway. Could only get my hand in so far.
03-06-2023, 03:08 PM | #4 |
Here's a link so you can see the area that fills up with debris from the cowl vent.
The arrows in the photo show where the water drains past. http://67-72chevytrucks.com/vboard/s...d.php?t=721974 Blowing air from the bottom while vacuuming helps.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-06-2023, 04:20 PM | #5 | |
66 GMC Suburban Custom 66 Chevy K10 Suburban |
03-06-2023, 11:25 PM | #6 |
Thanks guys! I vacuumed them out but I m sure the drains are blocked. Anyhow thanks again.
03-07-2023, 05:13 PM | #7 |
You are all welcome!
03-06-2023, 11:55 PM | #8 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
