Old 03-08-2023, 07:35 PM   #1
tdangle
tdangle's Avatar
window regulator replacement
Has anyone replaced a regulator without having to remove the vent window assembly and side window glass? Seems like it might be possible???
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 03-09-2023, 12:53 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: window regulator replacement
If you remove the screws from the rear metal glass channel (one at the top and two at the bottom) and move it out of the way you could probably do it. You would have to figure out a way to hold the glass up after you removed it from the lower rollers, so you could get the regulator out.
LockDoc
Leon
Old 03-09-2023, 03:28 PM   #3
tdangle
tdangle's Avatar
LockDoc
That is what I was thinking. Holding the glass up should work with duct tape over the top of the frame.
Terry
Old 03-09-2023, 12:53 AM   #4
ESC
Junior Member
Heres one of a few videos on YouTube
https://youtu.be/RL7Q6sYeEMg
ESC is offline   Reply With Quote
