04-09-2023, 03:58 PM | #1 |
Interior light
I have power on both sides of bulb wires orange and white, so when attached nothing happens. When either wire is set to bulb and other side of bulb is run to ground it burns. New wiring harness and this is only problem I've had. Any suggestions?
04-09-2023, 04:09 PM | #2 |
Re: Interior light
The bulb will show +12v on either side. The circuit is always hot. It is switched to ground. Pull the bulb, then check voltage. Which ever wire is not hot is the switch to ground side.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-09-2023, 08:06 PM | #3 |
Re: Interior light
The orange wire is not grounded for some reason., so would it hurt if I ran a ground wire to this wire?
04-09-2023, 09:44 PM | #4 | |
Re: Interior light
The following is a very detailed and highly simplified description of how the dome light circuit works. If your new harness is color coded correctly and matches the original color code, the orange wire comes from a fuse in the fuse box. It's always hot, and probably branches off and provides feed voltage for more than one circuit, but it provides 12V on one of the terminals on the dome light.. DO NOT GROUND THIS WIRE!! Fuses will blow.. The other terminal on the dome light should have a white wire connected to it IF the harness follows the original color coding. This is the wire that goes to a grounding switch, thus the term "switched to ground"... One of the switches used for this purpose is the headlight switch.. When the headlight switch knob is twisted CCW to the stop, the ground side is completed and the dome light comes on.. On some models (not all) of our trucks, push button grounding switches are installed in the A pillar between the hinges.. The white wire is connected to these switches and when a door is opened, the switch connects to ground and the dome light comes on.... |
04-09-2023, 11:39 PM | #5 |
Re: Interior light
Well, i beat my head against truck door for a couple hours with this. I tested wires from fuse box (orange and white) and there are two orange wires run into plug and one white wire and they plug into wire to interior light. The wiring harness is m & h and everything seems to work well. But, my white wire is hot and the orange wires don't complete the circuit. I don't know about why, but that is the way it is, so i have to go with it. I'm not getting a ground when i rotate the light switch all the way to left till i feel the indent. I can ground the light at bulb and it will burn, so i know my problem is with ground switching. Does the light switch have to be mounted and grounded? I'm not getting anything from orange wires. And, would i be experincing this problem if my headlight switch was bad? It's new but doesn't mean it's working correctly. This should have been relatively simple but its turn into a nightmare. Thank you for letting me pick your brain.
04-09-2023, 11:49 PM | #6 | |
Re: Interior light
RustyPile did a a bit better explaining than I did. Have you tried touching the switch to body while rotated to the on postion? Have not looked at wiring diagram in some time and do not know if switch has a ground wire.
04-10-2023, 02:10 AM | #7 | |
Re: Interior light
The following test will test the complete dome light circuit ----- You say one of the terminals of the dome light has voltage on it.. Install the bulb, and be sure the two wires' (white and orange) plugs near the fuse box are plugged into each other.. ... There is only one white wire on the headlight switch plug.. Using a jumper, clip one end to the white wire at the headlight switch.. touch the other end of the jumper to a suitable ground, the E-brake bracket is a good ground point.. The dome light should come on.. If it doesn't, there is probably an open in it between the dome light terminal and the headlight switch plug... |
04-09-2023, 08:15 PM | #8 |
Re: Interior light
The wire that does not have 12v is SWITCHED to ground. If it was grounded all the time the light would be on all the time. If your truck has door pins it should ground when doors are open. Also rotating the headlight switch to turn light on would cause it to ground.
