70+ ( Old Skool Club )
![]() Join Date: Nov 2003
What does this wire attach to ?
We have the wiring figured out except for the big red wire in the picture over engine. It has 2 female connectors on the end and look to bed a little thicker than most other wires. We cant figure where it is on the wiring diagram either. Anyone know what it connects to ? I also posted this in the Electrical Thread. Just realized my truck has factory A/C and do not see anything on wiring Schematic showing the compressor wiring.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 04-11-2023 at 08:46 PM. |
Who Changed This?
![]() Join Date: Jan 2013
Re: What does this wire attach to ?
It looks purple to me. That would be to the starter solenoid "S" terminal, except that has a round end for the stud on the solenoid. Looking at the 12R wiring, I'm not seeing a place except possibly at the voltage regulator.
Thanks for the reply. It does look a little purple I guess but its not the starter wire as its connected already.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Apr 2016
Trace the wire back to the firewall block where it goes in the cab. What position is it in? Or does it go somewhere else? Why do you say it has 2 female connectors on the end? The picture does not seem to show that.
Your right its a single connector..
I see your truck has factory air conditioning. In the factory AC wiring, the wire carrying power from the blower relay to the blower is purple..
Vettevet posted a wiring diagram in an old 2016 thread. http://67-72chevytrucks.com/vboard/s...d.php?t=705082 |
I would think it goes to the idle solenoid
![]() ![]() Join Date: Sep 2008
Fast idle solenoid for AC. See it just to the right of the thermostat? I can get a better pic if you need it.
Another.
Thanks Larry and pic is from original engine and looks like that wire came down the drivers side of the block on mine.
I think you are right. I will review my pre resto pictures.
I'm no expert, but I've been to many trips to the junkyard and I've never noticed a car with that solenoid using wire of greater gauge than maybe 16, tops.
Who Changed This?
I'm used to a green(?) wire, about 16 Ga. Things get modified over the years. That fat wire looks like if would be pretty tight in the clip on the valve cover.
regardless of color or terminal type, do not just blindly connect this wire to some random accessory.. Looking at photographs to determine where it might connect is pure guess work no matter who is doing the guessing. Trace the wire back to its point of origin and refer to a wiring diagram to determine EXACTLY where it goes..
#15 | |
Who Changed This?
#16 | |
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#17 |
![]() Join Date: May 2006
Funny guyROTFLMAF per se
#18 |
Thanks everyone but the wire is in itsrightocaion now as are all the others and fond out a couple were redundant. Just s just about donw witha few small details to button up. Snow and Winter road grudge are almost so can drive the truck when done.
#19 |
Member
If it's RED I a have a similar wire that goes to my tach. Old pics, but the location and size look similar.
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
