Old 04-15-2023, 09:28 AM   #1
K10-Kansas
K10-Kansas's Avatar
Truck turns over but wont fire
EDIT 4-30-23: I did start today!!!
1) I had my kill switch set up wrong so I bypassed it.
2) The plugs were completely fouled so I replaced them.
3) When I pulled the distributer I put in back in incorrectly so I fixed that (Thanks Ironangel for all of the great advice).
4) I had mislabeled the plug order on the distributer and therefore, connected the wrong distributer origin wires to the wrong plugs so I fixed that. LOL, check out the picture in post #22
5) The ignition wire had a bulky plastic housing over the female connector so it was very hard to know if it was actually ever properly connected to the battery male blade on the distributor.
6) It's also entirely possible that it wont start with the tach wire connected to the distributer. I'll try to start it tomorrow with the tach wire connected.
I have a 1971 K10. I bought it, had a mechanic put in a crate engine and transmission. It took him 4 months. The wiring was a disaster under the dash so I drove it onto a trailer and brought it home. I drove it off the trailer and parked it. I pulled every inch of wire bumper to bumper and replaced it with the American AutoWire Classic update. It took me 4 months because I could only work on it for a few hours per week. I'm done and was overjoyed to start the finished product. It turns over but wont fire.
I don't see where any wires got knocked lose. I thought about syphoning out the year old gas and adding new gas. What should I look at? Thanks for the help on this.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 04-15-2023, 09:47 AM   #2
PbFut
Re: Truck turns over but wont fire
Gas could be problem given the 8 months down time but I would verify you have spark first. Then verify fuel at the carb.
PbFut is offline   Reply With Quote
Old 04-15-2023, 10:03 AM   #3
kaycee
kaycee's Avatar
Start with the basics does it have spark, fuel check to see if you have spark if you do go to fuel is it getting fuel. Did it ever run after engine replacement
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 04-15-2023, 02:15 PM   #4
K10-Kansas
K10-Kansas's Avatar
Yes, it ran after the engine and transmission were put in. Thanks for your help on this.
Old 04-15-2023, 02:19 PM   #5
Getter-Done
Getter-Done's Avatar
I will add when trying to restart a vehicle that has not run in a while.
It is best to have a water source or fire extinguisher close by.
84 Chevy K-20
Old 04-16-2023, 12:40 PM   #6
K10-Kansas
K10-Kansas's Avatar
Thanks. I strapped a quick release auto fire extinguisher to the truck before I began replacing the wiring harness. Good info for people to read.
Old 04-15-2023, 02:14 PM   #7
K10-Kansas
K10-Kansas's Avatar
Thanks. I looked up some videos on how to do that and I'll check it out.
Old 04-15-2023, 05:40 PM   #8
guyryan100
guyryan100's Avatar
My truck sat for 19 years and the gas in the tank was fine when I fired it up late last year. Today I used gas from the lawn mower gas can because I needed to, that gas was 3 years old and ran fine. Both of these surprised me, just saying I bet old gas isn’t your issue. I bet power to the distributor.
guyryan100 is offline   Reply With Quote
Old 04-16-2023, 12:41 PM   #9
K10-Kansas
K10-Kansas's Avatar
Thanks. Good to know it's probably not the gas.
Old 04-15-2023, 07:20 PM   #10
72SB
Given it ran before you replaced all wiring....I would focus on wiring. Specifically, ignition (12vdc to yellow wire with key on)
You need to confirm if you have spark. pull a plug lay on block, crank...do you see spark?
If so look for fuel delivery issue
Your gas age is not a issue
72SB is offline   Reply With Quote
Old 04-16-2023, 09:19 AM   #11
rockyrivermark
Timing light is also a very easy way to check for spark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 04-16-2023, 09:52 AM   #12
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Does the truck have an HEI or points ignition? I dont think your problem is fuel, it's something you've done or didn't do in installing the new harness.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-16-2023, 09:59 AM   #13
ghackett1
68 C10 Longbed
ghackett1's Avatar
Yep agree, if it’s HEI be sure you have a solid 12 volts (I usually use the Fused ignition from the under dash fuse block) going to the coil/dizzy etc.. tape up that yellow wire and don’t use it — it’s a resistor wire to be used with points only.
ghackett1 is offline   Reply With Quote
Old 04-16-2023, 12:44 PM   #14
K10-Kansas
K10-Kansas's Avatar
Yeah, American Autowire had 2 sets of directions for HEI versus points so I followed the directions to sidestep the ballast resistor option.
Old 04-16-2023, 12:42 PM   #15
K10-Kansas
K10-Kansas's Avatar
Yeah, it was my first time doing anything like this so I bet that's it.
Old 04-16-2023, 10:30 AM   #16
geezer#99
geezer#99's Avatar
Yellow wire isn’t a resistor wire.
It’s the wire used to supply 12v to the coil (from the starter solenoid) when starting.
geezer#99 is online now   Reply With Quote
Old 04-16-2023, 01:14 PM   #17
ghackett1
68 C10 Longbed
ghackett1's Avatar
Yes correct—poor selection of words but I still also get rid of it when switching to HEi.
Old 04-16-2023, 01:28 PM   #18
RustyPile
RustyPile's Avatar
Yes it does but it also drops the voltage down once engine starts, so I may be wrong but I have always have seen it described as the resistor wire. I always disconnect when upgrading to HEI.
The yellow wire is not a resistor, therefore it does not "drop the voltage".. It is a simple jumper that runs between coil and starter solenoid. The resistor wire also connects to the same terminal on the coil. While the starter is engaged, 12 volts from the solenoid appears on the yellow wire at the coil.. When the engine starts and the solenoid disengages, the voltage to power the coil comes through the resistor wire where the "voltage drop" occurs.
Now, back to the regularly scheduled program.
RustyPile is offline   Reply With Quote
Old 04-16-2023, 01:36 PM   #19
ghackett1
68 C10 Longbed
ghackett1's Avatar
Got it
Old 04-16-2023, 01:46 PM   #20
Ironangel
Ironangel's Avatar
Our trucks didn't have ballast resisters, they use a resister wire usually coming from the wire gutter along the firewall to the coil. If your truck had an idle solenoid for the TSC system it used a 10 or 12 gauge pink wire. Buy installing an HEI that resister wire is of no use any more. All you need to do is find a switched terminal on the fuse box, an open spade terminal that is hot only when the key is on, and run a 12 gauge wire from that terminal to the BAT terminal on the HEI. You can actually run a wire straight from the battery + to the HEI and crank the starter, if it fires up you know you had a power issue and need to run that wire from the switched terminal in the fuse block so the truck shuts off with the key. You can 86 that yellow wire too, dont need it anymore. Only two wires for an HEI, the red power supply and the tach wire. Battery should ground to the engine block, the HEI gets it's ground through the block. I mentioned that pink wire because that's what many use for the switched power to the HEI. Since you stripped the factory wiring it may not exist anymore. No biggie, just do the above and your golden. I'm in KC pretty regular, where are located, north hopefully? I ask because I'll be in KC probably tomorrow and later in the week...I'd be glad to swing by and help.
"Two Seventy Two's"
02 3/4 ton Express
Old 04-16-2023, 09:44 PM   #21
K10-Kansas
K10-Kansas's Avatar
Thanks. I'm in Lenexa Kansas. I the American Autowire has a 12V wire running to the batt side of the HEI and the tach wire running to the tach side. I put my multimeter on the batt wire and it is sending 12 volts to the HEI. I pulled a spark plug, put it back in he wire and laid it on the block so that it is grounded and cranked the engine but got no spark. My HEI is brand new and worked fine before I replaced the wiring harness.
Old 04-16-2023, 02:42 PM   #22
Rust_never_sleeps
Rust_never_sleeps's Avatar
Maybe verify the condition of the grounds first. If you had to replace the wiring, those might be a mess too. Bad grounds will make troubleshooting a nightmare
Rust_never_sleeps is offline   Reply With Quote
Old 04-16-2023, 09:46 PM   #23
K10-Kansas
K10-Kansas's Avatar
Thanks. Yeah I put in ground straps and then doubled up by also adding ground wires.
Old 04-16-2023, 10:12 PM   #24
It is not uncommon at all for the HEI module to just give up with out warning. If you take it out, most auto parts store can test them. I know a lot of folks always carry a spare one in the glove box.
Old 04-17-2023, 06:46 AM   #25
K10-Kansas
K10-Kansas's Avatar
Thanks. I went and looked up info on that and found some testing steps on YouTube. I'll go ahead and test the parts of the HEI after work today. It'll be a good story when I finally find the culprit.
