04-17-2023, 01:39 PM | #1 |
1968 GMC C2500 Vapor Canister
I have a question about the Vapor Canister on my 396 GMC. I've attached a pic below. The large nipple on the canister attaches to the intake manifold. The small one goes to a line that goes through the firewall. I can't easily see where it goes from there. Where does it go and what does it connect to?
I don't understand the function of this canister as there is no line going back to the gas tank; just somewhere behind the dash board. Could I just block this vacuum line at the manifold? I'd appreciate an explanation. |
04-17-2023, 01:47 PM | #2 |
Re: 1968 GMC C2500 Vapor Canister
That’s a vacuum can, not a vapor canister.
Likely used to supply a bigger volume of vacuum for possibly the heater controls under the dash. |
04-17-2023, 02:03 PM | #3 |
Now I see; thank you. The tune-up decal under the hood states to remove the hose to the vapor canister; I don't see one on my truck.
04-17-2023, 06:00 PM | #4 |
Has the hood been changed on your truck?? Post a clear closeup picture of the decal. The year of application should be printed on the decal..
04-17-2023, 07:54 PM | #5 | |
The big vacuum can on the A/C housing is related to the A/C system as stated above. https://www.classicindustries.com/pr...-1199932086060 How are things in Door County?
Jim Last edited by FirstOwner69; 04-18-2023 at 12:14 PM. |
04-17-2023, 02:05 PM | #6 |
Vapour canister(aka charcoal filter) might be located under your battery.
04-17-2023, 02:26 PM | #7 |
Nothing under the battery. I wonder if someone put the wrong tune-up instructions under the hood. Looked in Classic Parts and they don't show a tune-up decal for a '68. At any rate, that vacuum hose is old and brittle, so I'll chase those down and replace them. Thanks for your help.
04-17-2023, 04:30 PM | #8 |
Who Changed This?
'68 did not have a vapor canister; those started in '70 on light duty trucks- 1/2T (and only California, to boot).
