Old 04-17-2023, 09:55 PM   #1
slugish
Slugish
ignition switch replacement help !
It looks like you have to remove the steering collum to get to the switch on top of the collum - The collum will not drop down enough to get to it - Am I missing something 84 c-10 automatic
slugish is offline   Reply With Quote
Old 04-18-2023, 07:12 AM   #2
v30crewcab
v30crewcab's Avatar
Re: ignition switch replacement help !
i've always just reached up and unbolted them. not easy but can be done.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-18-2023, 03:29 PM   #3
rodstored-72
chevy truck fan
rodstored-72's Avatar
ditto.. i just replaced mine a bit ago and i just dropped the column down and finagled myhand/arm in there to do it..
good luck!
rodstored-72 is offline   Reply With Quote
Old 04-20-2023, 11:39 AM   #4
kwmech
loosen column enough to see it. small socket 5/16 (i think) and 1/4 drive ratchet
Old 04-22-2023, 02:51 PM   #5
Pontiac1976
Pontiac1976's Avatar
As said by both: v30crewcab
kwmech
Good luck some time blanket helps neck head when under there.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
