04-23-2023, 01:01 PM | #1 |
Junior Member
Can anyone ID this loose wire?
I'm replacing plugs and wires and found this wire sitting below the alternator, not connected. It's in a heat-resistant sleeve running along the valve cover to the rear of the engine and into a harness. Does it look familiar??
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again. "For just a little more, you can do it yourself!" |
04-23-2023, 01:14 PM | #2 |
Re: Can anyone ID this loose wire?
Looks like the Temperature sensor wire.
Should be a sensor between #1 and #3 spark plugs. |
04-23-2023, 02:48 PM | #3 |
^^ what he said ^^
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
04-23-2023, 03:18 PM | #4 | |
Hey , your alternator is on the wrong side .
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
04-23-2023, 04:05 PM | #5 | |
Alternator on Drivers Side is normal with short water pump.
04-23-2023, 07:55 PM | #6 |
Junior Member
That's it! Thank you!!
04-23-2023, 08:27 PM | #7 |
68 C10 Longbed
