Old 04-25-2023, 07:14 AM   #1
chrismoore701
chrismoore701's Avatar
Shaving lower control arm
I dropped my truck a few years ago and I noticed my wheel weight is getting shaved by the lower control arm.
Any harm in grinding about 1/4"-3/8" off the lip of the lower control arm?
Chris
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-25-2023, 08:37 AM   #2
Rich84
Rich84's Avatar
Re: Shaving lower control arm
No harm at all. I did it about 6 years ago. No issues.
Rich84 is offline   Reply With Quote
Old 04-27-2023, 09:25 AM   #3
SCOTI
SCOTI's Avatar
How you trim them is where 'harm' can be introduced.
Don't cut the lip w/90° edges. No hard edges helps to minimize stress crack opportunities. You want nice rounded/curved transitions where you decide to start the shaving of the lip.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-28-2023, 10:39 PM   #4
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I don't recall how much was trimmed, but it was trimmed when Beltec lowering spindles were installed and used 15" aluminum wheels... instructions clearly stated use of 16" wheels or something similar.... but... when I was on the freeway, heard/felt something unusual, pulled over to the emergency lane, nothing leaking, nothing abnormal... continued about another 1/4 mile and control arm finally snapped, wheel went into the wheel well, put almost strait into the concern barrier.
New frame, new a lot and back on the road... Id say get bigger wheels, different wheels or different wheel weights but, theirs always success stories... I just happen to have a bad one
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 05-02-2023, 06:54 AM   #5
TrailerTrash
TrailerTrash's Avatar
I had the same issue with my 15" wheels and Western Chassis drop spindles.
I went to my regular tire shop and told them about it. They moves the weights to the front lip and I think one wheel needed a stick on weight on the inside of the barrel.
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 05-02-2023, 08:47 AM   #6
SCOTI
SCOTI's Avatar
Contact interference happens w/any spindle when using a 15" wheel & back-spacing beyond a certain dimension (3.75"?). It's not just one particular brand.
Adding wheel weights to the front or using the tape on weights is another way to combat the issue since the weights clipped to the rear lip is usually the first thing to make contact.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
