1971 GMC K15 4x4 radiator
Hello all, sorta new to the forum but have lurked for a while. Does anyone have any experience with the aluminum radiators like you can find on Ebay and Rock Auto?
Re: 1971 GMC K15 4x4 radiator
Welcome to the forum. I am sure there are a few on here that have installed aluminum radiators. I tried a Champion radiator but it did not work in the Texas heat with the AC on. So I had a custom radiator built by Wizard Cooling. Pricey but well worth it so far.
Thank you!
They suck...have yours repaired or buy a copper brass reproduction
From Summit or a Dewitts Made in USA |
#6 | |
![]() Join Date: Feb 2002
I have a '71 GMC Jimmy K/1500 w/ V8 350, My 4-tier core copper/brass radiator is in the shop, as we speak. Estimated cost for rebuild, re-rodding: $250. But I know it fits. OBTW, nice Stepside. ![]()
20' Daredevil (Ret)
![]() Join Date: May 2003
A few years ago my non-oem 4-row brass/copper radiator developed a few small leaks. I read up on aluminum ones and asked around, kinda like you are doing now. I don't recall all the pros & cons, but after talking with a guy at a radiator shop, I decided to have mine repaired. I'm still happy with my decision.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Champion let me down. I would buy oem next time and probably will anyway myself.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
![]() Join Date: Jul 2001
I had my 4 row Harrison repaired for my 71 4x4 and has worked well since. Had the 4 row Harrison re-cored for my 71 Chevelle, pricey but rock solid at 190 degrees in Kansas heat and the Vintage Air cooling well. Had the original Harrison repaired in my 57 2 dr sedan and it stays rock solid at 180 in Kansas heat. I'm a big fan of and nothing fits and works like original GM parts.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Thanks all, I may just repair the original.
I'd repair the original for sure that way you know it's a perfect fit and it's made to last. I just upgraded my rad to a 3 Core Original. Had it cleaned and pressure tested and I'm good to go.
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
One of the reasons I was considering replacing it is that there are no radiator shops here anymore.
As you all know those original 4 tube radiators were overbuilt for factory installed AC. When my 70 K20 developed a few leaks I located a vintage radiator shop in my community and they flow tested my 4 tube before attempting any repair work. Based on their past experience I was told that they could close up to ten tubes and that I shouldn't experience any overheating problems. I kept my original radiator and the temperature gauge still reads normal. I run a 195 thermostat and have always used a Stant 10 lb cap open system. Mongo4298
My truck was originally optioned with AC and came with a 16 lb radiator cap.
AC is long gone, but I still run a 16 lb cap. While my radiator is in the shop getting rebuilt, I pulled the Battery Box and installed an overflow jug next to it. It's an OER part for an '80s Nova, but it slips right in inside the passenger side fender and is mounted just aft of the Fusible Link Terminal. I have no prior experience with these, so I'm curious if I should get a lighter rated radiator cap?
#15 |
20' Daredevil (Ret)
I have always run a 16# cap. Pretty sure that's what the factory calls for, and I've never had a problem with it. Also have an aftermarket recovery bottle that was on the truck when I bought it, so I'm using a cap for a sealed system.
#16 | |
Have a brand and P/N?
#17 | |
20' Daredevil (Ret)
With a recovery tank, you fill the radiator to the top. Shut the engine off at operating temperature and some coolant will be forced out into the tank. (The old way, it would be puked out onto the ground). As the system cools, your new cap -- which has two seals -- will allow coolant to be drawn back into the radiator. Your old cap, with a single seal, won't do that.
#18 | |
Not sure how long the shop will be fixing my radiator. I dropped it off Thursday, and they got back to me Friday morning with an estimate. I think they're now the only game in town.
#19 |
Thanks very much to all for the help and kind words!!
#20 | |
20' Daredevil (Ret)
Any parts store should have an equivalent cap. Just be sure it has the double seal.
#21 | |
#22 |
![]() Join Date: Nov 2018
Well I guess I will be the odd man out, I am currently running 3 Champion Aluminum Radiators, one for about 20 years now, another for about 7 years and one in my avatar for about 3 years now, all 3 vehicles have A/C and run thermostatic controlled electric fans.
I have not experienced a single problem with any of them. Just my experience with Champion Radiators. |
#23 |
OK. I got a MotoRad radiator T16V cap at O'Reilly's last night for about $8.
Performance Radiator called me. My 4-tier copper/brass unit is ready for picking up.
#24 |
Curious if you don't mind posting, what did the radiator shop find and the cost to repair? My 4 row radiator had two pin hole leaks, a weeping tank and was boiled and rodded for $30. Course, that was about 15 years ago,
![]() My re-core for my 71 Chevelle 4 years ago was $435.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 05-02-2023 at 06:16 PM. |
#25 | |
They said it was 20% plugged, and was leaking on both tanks. [Passenger Side was massive.] 225 labor, 20 shop supplies, 5 ''environmental fee'' and $2.18 AZ state sales tax. [The estimate was for $250] I had asked them to reclock the overflow tube from 3 o'clock [pointing at the battery] to 6 o'clock [pointing straight back] They only moved it to 4 o'clock. With a 90* angle fitting, I can make out. I'm p!ssed I didn't catch that before I left the shop. Other than that, I guess they did OK. Fresh glossy black paint. 30 day guarantee.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-04-2023 at 05:34 AM. |
