05-07-2023, 08:46 PM | #1 |
How do air shocks work or operate
On my 69 4 door Nova I am using 3" drop springs from Hotchkiss, and I am likely to add lowering spindles to get another inch. As the true drop has not been far enough for my taste. Currently it's only a 1/2" lower then when the original springs were there.
So to increase my cars weight carrying capacity in terms of weight before the tail drags everything. I want to add air shocks to the suspension off a braced section of the subframe. So I will have 4 shocks in the rear. The normal shocks will be KYB gas adjust. If I add air shocks will they increase my cars shock dampening in the rear. Or do they only do that when air is added. |
05-07-2023, 08:50 PM | #2 |
Re: How do air shocks work or operate
You will pretty much double your dampening of the shocks. Air shocks are regular shocks with an air bladder. I would look at doing something like an airlift setup over air shocks.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-08-2023, 12:12 PM | #3 |
Damn they were a easy fit.
Well I will look to some sort of sleeve bag or small bellows bag |
